For Lean Burn the TPS has to be 35 or less, as read on a ScanGauge II. I think OBDIIC&C displays it as like a voltage or something if you get one of those.
Properly indexed spark plugs are supposed to help with lean burn.
Shot in the dark:
Maybe your knock sensor needs to be replaced? Uhh like, the plastic could be splitting apart and the probe is loose. No CEL if this happens but it could be throwing weird signals and the timing could be affected.
@ eq1 and Willie:
G2 doesn't have a SOC gauge on the dash. But there's a really rudimentary one that provides you with no useful information which you can select from the infographic display options.
Shot in the dark:
@ eq1 and Willie:
