I decided to try to limit the amount of energy wasted using the dc/dc converter. So here is what I have done so far:
1) 3 watt PV panel (ebay vw solar panel) suction cupped to the inside rear window at the top. I used an RCA M/F 6' cable and cut it in two 2' from the M end. I removed the dome light assembly and hard wired the 4' F section to it (center positive) with a reverse blocking diode. I then used a piece of steel pallet strapping as a fish and shoved it above the headliner from the hatch to the dome light opening. The F connector was then taped to the end if the fish and pulled back to the hatch area. Then I put the light assembly back in. The 2' M cable was soldered to the PV panel wire and insulated with electrical tape and covered with some heat shrink. The connectors are mated above the headliner.
2) I ordered LED bulbs from http://www.superbrightleds.com
Used WLED-W6 to replace the dome bulbs, license plate light, and the two forward pointing parking lights.
Used 7443-R15 to replace the brake light bulbs.
Used 3022-W4 to replace the hatch light bulb.
LIGHTING ENERGY SAVINGS:
The dome lights and hatch light are hardly ever on so not much energy will be saved. I like the cool white hint of blue much better than the stock yellowish color though.
When the parking lights or headlights are on there is a good amount of power saved and since they are on for long periods of time there should be pretty good energy savings.
PARKING LIGHTS ON (brake pedal not pressed):
STOCK = 35W (tailights 10W, license plate 5W, parking lights 10W, side markers 10W)
LED = 12W (tailights 1W, license plate 0.3W, parking lights 0.6W, side markers 10W)
SAVINGS = 23W
PARKING LIGHTS ON (brake pedal pressed):
STOCK = 70W (tailights 42W, center brake 3.1W, license plate 5W, parking lights 10W, side markers 10W)
LED = 16W (tailights 2.2W, center brake 3.1W, license plate 0.3W, parking lights 0.6W, side markers 10W)
SAVINGS = 54W
SAVINGS = 23W
SAVINGS = 54W
