1 - 2 of 2 Posts
Has anyone replaced their flasher / turn signal / hazard relay with an LED flasher relay to eliminate the hyperblink from LEDs?
If so which relay did you use? I've noted that the Insight requires an EP34 flasher relay, but the one relay I found mentioned on here is an EP35...are the two cross compatible? How about the CF13? They all look to be the same...on the outside, at least, but I don't want to accidentally order an incompatible relay.
The relay in the Insight is about 1"x1", yet all the ones for sale seem to be 1.2"x1.2", which seems to pose a fitment problem from my measurements. Is this so, and if so, what have you done to fix this? Or do the 1.2"x1.2" flasher relays fit fine?
Thanks!
This is the one I got from Amazon
I had to add some extension leads to connect to the fuse block
iJDMTOY (1) 3-Pin CF-13 CF13 EP34 Electronic Flasher Relay Fix w/Speed Adjustable Function For LED Turn Signal Light Bulbs Resolve Rapid Quick Flash Issue
1 - 2 of 2 Posts
