Anybody have a favorite that works well on Insights and lasts a long time? I usually use Super Bright LEDs, but they don't have any amber ones in stock right now. I can wait, but I thought I'd explore other options.
My turn signals are still incandescent. A resistor is one way to fix the fast flashing, but I think using a different flasher is the better way.do you run a resistor with the LEDs to keep it from flashing quickly?
Any suggestions which flasher works better with LED turn signals?My turn signals are still incandescent. A resistor is one way to fix the fast flashing, but I think using a different flasher is the better way.
That's what I was wondering. On my Celica I got a different flasher relay so I didn't need any resistor for the LED turn signals. Like Calpod, I'd like to know too if you got a different flasher in mind.My turn signals are still incandescent. A resistor is one way to fix the fast flashing, but I think using a different flasher is the better way.
That sounds a bit like a fluke. I doubt tail lights could have that kind of effect on an old OBD2 car. Maybe something weird on a newer CANBUS car, but I don't think 1G has any real connection with the brake lights themselves, just the brake light switch.The Insight, however, did not like them on the brake lights: I forget exactly what effect it had on the mileage display, or maybe the auto-stop function, but something was off immediately.
Places that sell LED bulbs usually offer a compatible flasher. I think some "heavy duty" flashers will work as well.Any suggestions which flasher works better with LED turn signals?
You have to watch the overall length on the front turn signals because most of them won't fit. I put this one in https://www.amazon.com/dp/B07Q8RZRZV?psc=1&ref=ppx_yo2ov_dt_b_product_details and it works, but it's at a slight angle since it wouldn't fit in straight, overall length is 2.05". They have worked fine since Thanksgiving, but I plan on installing these, https://www.amazon.com/dp/B07BXP49Q4?psc=1&ref=ppx_yo2ov_dt_b_product_details because the overall length is 1.66". The longer ones fit fine in the rear turn signals and they don't hyperflash, the resistor is built in to the bulb. For the brake lights I put in these, https://www.amazon.com/dp/B09P15SG44?psc=1&ref=ppx_yo2ov_dt_b_product_details and they work great. For the backup lights I installed https://www.amazon.com/dp/B08KFS93PS?psc=1&ref=ppx_yo2ov_dt_b_product_details Since I have a 2000 Citrus I installed green parking lights in the front, https://www.amazon.com/dp/B088H7PXS6?psc=1&ref=ppx_yo2ov_dt_b_product_details For the headlights I used these and they work great https://www.amazon.com/gp/product/B071R3KTBB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1Anybody have a favorite that works well on Insights and lasts a long time? I usually use Super Bright LEDs, but they don't have any amber ones in stock right now. I can wait, but I thought I'd explore other options.
This is what I'd highly recommend (and use myself), especially if you're looking for quality and want them to last the lifetime of your vehicle - Vleds Turn Signal Bulb.Anybody have a favorite that works well on Insights and lasts a long time? I usually use Super Bright LEDs, but they don't have any amber ones in stock right now. I can wait, but I thought I'd explore other options.
I ordered an adjustable flasher relay from eBay and honestly thought it won't last as long as it has so far. Something along the lines of this - Adjustable Flasher RelayAny suggestions which flasher works better with LED turn signals?
Agreed 100% - quality over quantity any day!If LEDs are for your Insight, please do justice by choosing automotive grade leds from reputable brands with some experience like Philips, Sylvania, etc and skip ebay noname leds that "are brighter" but dies weeks later for the same price.
That being said, I was able to track down old school discontinued Philips xtreme Ultinons for every bulb in the Insight. I use ambers for turn signals and red for brakes have yet experience any problems comming from Phillips leds which came with 7-14years warranty at the time. Some are still available now if you do some digging thru chinese led jungle.
To fix hyperflash from turn signals, I use Novita signal flash relay available at AutoZone model EP26, EP27, EP28, EP29, or EP34 to replace original one under dash/steering. My research lead me to part number that still hyperflash but I was able to test and return on the spot for the correct one.
! Note. ! Turn signals still flash faster than oem but no where near as fast or ennoying as without relay.
Rant! Highly recommend replacing rear brake lamp 7440 to LEDs as a safety enhancement priority in ones to-do list especially for an Insight due to LED response being much faster than incandescant bulbs. Meaning when you step on the brake pedal, those behind you will see your brake light illuminate faster than oppose to oem incandescant bulbs, plus no "ghosting" from on to off. This would give those behind our insights an extra second to react and not total our aluminum can cars from a rear end collision.
