Here is some information I've collected regarding the 47Ah FoMoCo modules.
Somewhat recently, I remember hearing about the 4xE issues within the last month or so. Sounds like there is going to be a lot more of these cells on the market.Recalled on what date?
Correct: my understanding is that the battery tab welding machine wasn't calibrated correctly, and was under-attaching the cell terminals. This lowers their maximum current handing capabilities, but Linsight doesn't get anywhere close to the current Ford is using in their vehicles. Also, with LiBCM even if a tab did open, there's no safety issue... you'll just get a CEL and the IMA system will disable. There could also be damage to the LiBCM PCB, but it doesn't pose a safety risk.I recall mudder writing that the problem was poor ability to pass max amperage as used in a full battery electric vehicle. We'll be using a much lower max draw, so no problem for our application.
A client of mine is working on wholesaling some "recalled" Kona packs. From my understanding they're removed from the vehicle for the chance they're part of the recall, and when it's found they don't contain recalled components they are cleared for rebuild/scrap. (Very wasteful process, I'm surprised they don't have a record of what components went into each pack.)The supplier I purchased these modules from said they weren't related to the recall... but I don't know where else they'd be coming from. I have a hunch they're recalled modules... can't prove it.
I'd get QTY5 modules, so you can use either QTY4 or QTY5. With the IMA cover off, changing between the two configurations takes only a few minutes. All you have to do is unplug one Anderson cable and plug it into another one, and then update the firmware.** The only tools you need are those to remove the IMA cover itself.John, I continue to ponder whether I want to go with 4 or 5 of the 47Ah FoMoCo batteries
Just to clarify: 60S (QTY5 module) configuration supports background charging. It's just slightly weaker than OEM, unless you're using a manual IMA controller (in which case you can assist and regen as you please, just as long as engine RPM is high enough. For example, I can regen at full power at 3000 RPM. I have no idea how this translates to the CVT, but my understanding is the CVT already operates at higher RPM than the MT, so I suspect there isn't an issue.I'm pondering the lack of background charging in the 60S version.
60S (QTY5 module) LiBCM can charge at full power, even when the battery is almost fully charged... you just need higher engine RPM. In general I'm finding that with 60S I tend to stay in lower gears than I used to... but that's just because I like to drive entirely with the electric motor.My wife's plugin Prius works like this: it is a PHEV until the state of charge gets low enough that it starts operating like a traditional (non-plugin) hybrid. When the SOC reaches that point, it still has regen braking and engine background charging as needed. However, in the absence of serious regen braking (think going down a long, steep mountain), the SOC never again gets high enough to run in pure EV mode until I plug the car back in and grid charge.
I've actually improved OEM regen behavior since writing that statement. Note that since I now primarily operate in manual IMA mode, I can basically keep the SoC at any level I desire, just as long as engine RPM is high enough.You've said that the 60S FoMoCo solution " is able to regen a 60S pack when you let off the gas and/or apply the brake. However, the typical background regen when the pack is low doesn't actually charge the pack. This causes the pack to tend towards discharged."
I was using manual IMA control on that trip. I specifically wanted to arrive at my destination with an empty pack.When you wrote about your trip to Wisconsin, you wrote "I arrived at our destination with 11% SoC (i.e. 1% left to spare)." If you had not had access to any grid chargers and you then had to continue your trip to, say, San Francisco, what would have happened? Would you essentially be driving the rest of your trip with out any hybrid assist?
Total trip duration (hours) | Average Assist (kW) | Average Assist (HP) |
0.5 | 15.6 | 20.8 |
1.0 | 7.8 | 10.4 |
2 | 3.9 | 5.2 |
3 | 2.6 | 3.5 |
4 | 2.0 | 2.7 |
5 | 1.6 | 2.1 |
10 | 0.8 | 1.0 |
See above. Either 48S (QTY4 modules) or 60S (QTY5 modules) will work just fine. You'd opt for 48S if you "just want it to work", whereas you'd opt for 60S if you "just want it to work eventually".If that is so, and if I want my Insight to be able to engine charge so that once the SOC gets low enough, that I can continue to drive it as a traditional hybrid . . . then that means that I should prefer the 48S FoMoCo, right?
If you don't use a manual IMA controller, right now the SoC behavior is basically identical to OEM:If I go with the 48S, can I prevent the car from force charging all the way up to 50, or so, percent? In other words, will the software be configurable so that background engine charging might only force charge the required minimum so that the car can function as a traditional hybrid -- say between 15-25% SOC?
I could NEVER go back to a stock insight. It is so much more fun to drive a car with two separately controlled energy sources. On trips less than 20 miles I basically never use the gas pedal or OEM brakes (except when I come to a complete stop). On longer trips it's fun to optimize assist to increase MPG, but also use the gas pedal so as to conserve the assist until it's actually needed.What is the driving experience like with FoMoCo and manual IMA control?"
With a stock MT insight:How much will mpg increase?
Combined with the excellent +40% current hack, LiBCM presently improves IMA power by around 100%. It's a pretty huge difference, particularly with a manual IMA controller (which I recommend to take full advantage of the increased capacity).How much more power will I have when I need it?
If you absolutely cannot afford downtime, then my recommendation is to not install LiBCM at all, at least until it leaves beta. I wouldn't want to threaten your livelihood if LiBCM causes issues with your particular car. Do note that even if the IMA system fails, you'll still have the gas engine as a backup, so you won't be stranded, but you might be inconvenienced.Should I install this is my work car?
In short, it would take years - if ever - to recuperate your initial outlay. Let's look at the math:Will a 47Ah FoMoCo LiBCM car actually save money?
Expect the 47Ah conversion process to take twice as long. The individual steps are about the same difficulty... there's just more of them because this is completely replacing the OEM battery enclosure and repositioning several OEM components in the IMA bay. The FoMoCo installation videos will be of similar quality to those I already made for the 5AhG3 install.How much more difficult is it to install the FoMoCo Kit versus the 5AhG3 Kit?
I just don't wanna deal with getting fuel 🤷♂️🤷♂️. My commute is 18mi round trip, I would rarely ever have to fill up.(Paraphrased) answers to a few questions sent to me from a member:
10 kWh + manual IMA control is absolutely a game changer. This will come as no surprise to all those who've had larger (but not this large) lithium batteries for years now. This is nothing new... it's just better and more available to the general insight community.
Stay tuned for a video I plan to film next week wherein I show off the various driving strategies I've adopted now that I have a massively larger battery and a manual IMA controller.
-I pretty much always get mid-to-high 50 MPG (both highway and city).
-Before I moved to mountainous Chattanooga, I typically got 60 MPG.
-I once drove agonizingly slow for an entire tank, eeking out 750 miles before running out of gas.
After installing 47Ah FoMoCo and the manual IMA controller I designed:
-My around-town fuel MPG has increased from high-50s to over 200 MPG(fuel). You read that correctly.
-On 2 hour trips, I get around 150 MPG(fuel) on a single charge.
-On 10 hours trips, I get around 74 MPG(fuel) on a single charge.
-My last tank of fuel lasted just over 1000 miles. This might seem low given the numbers above, but I regularly drive several hours on a single trip, which requires more fuel (since I don't charge en route). If all trips on a single tank were less than 1 hour, then I'd expect to achieve around 2000 miles on a single tank of gas. If all trips on a single tank were less than 30 minutes, then you basically wouldn't use gas at all.
Note: I'm still pretty new to hypermiling and am still figuring out the ideal drive parameters. Those drivers that are already achieving over 100 MPG with stock NiMH batteries are going to laugh at how 'bad' my MPG numbers are.
Future hardware and/or firmware updates will increase power output even more. In particular, LiMCM - which replaces the OEM MCM - could potentially quadruple the OEM power output (but who knows for how long).
At this point I would drive my LiBCM-equipped car anywhere with zero notice.
The cheapest self-installed 47Ah FoMoCo option is $2800 ($1800 for the kit from me, plus $1000 for QTY4 (48S) FoMoCo modules).
Assuming you pay $3.50/gallon of gas, the cheapest LiBCM install costs the same as purchasing 800 gallons of gas, which is equivalent to driving 48,000 miles if you average 60 MPG. But it'll take even longer than that to recuperate your FoMoCo outlay, as you'll be consuming energy from the wall now, too. At $0.14/kWh, it costs $0.87 to fully charge an empty 48S FoMoCo pack. On my last tank, I used 110 kWh and drove just over 1000 miles. Using the numbers above, I spent $35 on gas ($3.50 * 10 gallons) and $15.40 on electricity ($0.14 * 110 kWh).
With a stock insight, I would have consumed 18 gallons of gas driving 1000 miles, which would cost $63 for fuel (and $0 for electricity). Therefore, I appear to have saved $12.60 driving 1000 miles. Therefore, to recoup the upfront LiBCM cost, I'd need to drive over 200,000 miles. This mileage will decrease substantially if you only ever drive short trips, particularly if your fuel-to-kWh expense ratio is higher than in my example above.
Note that if your gas price is higher, then your kWh price is probably also higher, too... which probably cancels out any regional differences.
So if your goal is to save money, it's going to take a while to achieve it. In general this holds true for all electric vehicles. The primary exception would be if you aren't the one paying the power bill. For example, if your work allows you to charge for free, then you'd end up saving $28/1000 miles (based on my usage pattern), which would require 'only' 100,000 miles to recoup the initial LiBCM outlay. If you're lucky enough to pay nothing to charge - and you only drive short trips - then you basically wouldn't use gas, in which case the initial "48,000 miles to break even" figure is valid.
However, if your goal is to have fun, improve the driving experience, or just to not emit CO2, then LiBCM might be just what you need. I'm great at marketing.
A gallon of fuel would probably last you all yearI just don't wanna deal with getting fuel 🤷♂️🤷♂️. My commute is 18mi round trip, I would rarely ever have to fill up.
Yes, I still have several sets available. If you'd like to reserve a set, please fill out this form.Do you still have FoMoCo modules available?
FYI: The modules I sell:I can buy FoMoCo modules cheaper from batteryhookup, including shipping.
I sell every part you need to perform the FoMoCo conversion. This includes all mechanicals required to safely mount the batteries, all cabling, all the nuts and bolts. Everything but the batteries is included with each Kit. The only thing you'll need is common tools (sockets, screw drivers, wire cutters, etc).What else do I need to perform the DIY FoMoCo conversion?
There are a few optional parts that you might also want:What optional parts do you recommend to make LiBCM even better?
Yes, but you will need to return the original charger you purchased (or pay more if you want to keep it).If I choose the basic charger for the 47ah battery, can I upgrade later?
It will be at least a couple months. Right now I'm working on improving the firmware, so that the 5AhG3 project can exit open beta. I don't know how long that will take, but there's a bunch of firmware work left. Once I have a 1.0.0 release candidate, I will focus on shipping FoMoCo kits. Note that there are presently QTY27 in line for the FoMoCo kit, so once the kits do start shipping, it'll be a bit before I ship additional reservations.When will DIY 47Ah FoMoCo LiBCM Kits start shipping?
I started shipping them as part of an Open Beta in 2022JAN. Right now I'm out of stock, and don't plan to build more until the firmware is further along (same timeline as previous question).When will DIY 5AhG3 FoMoCo LiBCM Kits start shipping?
No.Can I pay more to cut the line?
Yes. It will cost extra ($TBD). It should be available day 1.Will 47Ah FoMoCo also have a heater solution for cold weather?
All grid chargers I sell work with either 120 VAC or 240 VAC outlets.Which grid chargers work on which voltages?
Yes, and it works with all LiBCM kits, regardless of which grid charger is used.Does LiBCM support J1772 charging?
No. LiBCM is a bargain. Please stop asking.LiBCM is too expensive. Will you sell it to me for $XXXX?
No. I only sell kits.Will you install LiBCM in my car?
UK owners can get the current hack and larger fuses from me.There are a few optional parts that you might also want:
-a +40% current hack PCB (from @Bull Dog), which also requires a larger fuse (also from @Bull Dog).
-a manual IMA controller. There are several different versions sold by several different people. Note that after performing the FoMoCo conversion, there is very little room near the wire harness. Therefore, some manual IMA controllers are not compatible with the FoMoCo setup because there physically isn't enough room to install them. At present I do not know which existing manual IMA controllers will physically fit in the bay. Note that I will start selling a 100% compatible manual IMA controller later this year (probably a couple months after 47Ah FoMoCo starts shipping). If you don't already have a manual IMA controller, then my recommendation is to wait for that product to ship.
-a Nextion LCD touch screen, which is an upgrade to the 4x20 display that ships with LiBCM. User @Natalya is presently writing the UI for that product, which is called 'LiDisplay'.
It'll eventually all end up in the "Introducing the 47Ah LiBCM Lithium Conversion" post (to be made at a later date).Put all that in the first post!
Good to know! I wasn't sure whether your manual IMA controller fit entirely within the MCM or not... I knew part of it did, but great to hear it'll work with LiBCM FoMoCo!My IMAC&C P&P (manual control) is fitted inside the MCM so works happily with LiBCM/Linsight and is not space constrained.![]()
