FYI: I
A 1.0 Ah/h grid charger will take under 4 hours to charge the battery.
A 2.1 Ah/h grid charger will take under 2 hours to charge the battery.
A 4.2 Ah/h grid charger will take under 1 hour to charge the battery.
Whenever I quote charging time, I'm using 10% to 85% SoC, since that's the range LiBCM uses. Since the EHW5 modules are nominally 5 Ah, I'm quoting the time to charge 3.75 Ah (i.e. 75% SoC, which is 85% - 10%).Mudder, as I ponder what I want to do regarding faster charging and the final revision PCB, I dug up this post where you mention what grid chargers you would offer.
Are the above times for charging from 0%-100% or for some other range?
The grid charger included with Open Beta LiBCM Kits is 450 mAh/h, and so takes around 8 hours to charge the battery (if the firmware version is older than v0.7.3, it takes around 12 hours).Also, in your above post you mention that if we limited ourselves to a 1 Ah grid charger, we could probably stick to the current revision board. If we were able to locate such a grid charger, what would its charge times be?
