@mudder
I've installed the heater boards and trying to test for the LED blink, but I'm not sure I'm doing it correctly. The installed firmware is 0.8.5
I have the main breaker "off" that splits the pack in half
Everything is installed per the videos and I've opened up the fan shroud to view the LED
I plugged in my laptop, opened arduino and selected serial monitor.
(Libcm display is lit and is warning about the plexi cover not being installed.)
I enter $testh and hit enter...also tried control+enter...also tried $TESTH
I don't see the green LED flash
You mention to reverse a connector....is it the two pin heater connector connected directly to the Mega board?
I haven't done much with serial monitor, so I'm not sure I'm doing this correctly...here's a pic where I would enter "$testh"
Should the main breaker be "ON" for this test?
