Where I've gotten now is I can control text elements like the version info, but I still can't change the value of other elements.
There's another way the data can be formatted using bytes instead of the strings seen here. I'll look into that next and see if that lets me update bar graphs and numbers.
Code:
//Copyright 2021-2022(c) John Sullivan
//github.com/doppelhub/Honda_Insight_LiBCM
//LiDisplay (HMI) Serial Functions
#include "libcm.h"
bool versionAlreadyDisplayed = false;
uint8_t LiDisplayElementToUpdate = 0;
const String typeMap[3] = {
"j", "n", "t"
const String attrMap[2] = {
"txt", "val"
void LiDisplay_begin(void)
#ifdef LIDISPLAY_CONNECTED
Serial.print(F("\nLiDisplay BEGIN"));
Serial1.begin(9600,SERIAL_8E1);
/* Serial1.print("page0.j0.val=" + String('"') + String(SoC_getBatteryStateNow_percent()) + String('"'));
Serial1.write(0xFF);
Serial1.write(0xFF); */
//LiDisplay_writeByte(SoC_getBatteryStateNow_percent());
#endif
void LiDisplay_updateElement(uint8_t page, uint8_t elementTypeIndex, uint8_t elementId, uint8_t elementAttrIndex, String value) {
static String LiDisplay_Data_Str;
LiDisplay_Data_Str = "page" + String(page) + "." + typeMap[elementTypeIndex] + elementId + "." + attrMap[elementAttrIndex] + "=" + String('"') + value + String('"');
Serial1.print(LiDisplay_Data_Str);
Serial1.print("page0.t1.txt=" + String('"') + String(FW_VERSION) + String('"'));
Serial1.print("page0.n0.val=" + String('"') + String(SoC_getBatteryStateNow_percent()) + String('"'));
#endif
void LiDisplay_refresh(void)
//static uint8_t LiDisplayElementToUpdate = LCDUPDATE_NUMERRORS; //init round-robin with least likely state to have changed
static uint32_t millis_previous = 0;
#define LIDISPLAY_UPDATE_RATE_MILLIS 256 //one element is updated each time
if(millis() - millis_previous > LIDISPLAY_UPDATE_RATE_MILLIS)
millis_previous = millis();
switch(LiDisplayElementToUpdate)
case 0:
//LiDisplay_updateElement(0, 1, 0, 1, String(SoC_getBatteryStateNow_percent()));
LiDisplay_updateElement(0, 2, 1, 0, String(FW_VERSION));
break;
case 1:
//LiDisplay_updateElement(0, 2, 1, 0, String(555));
break;
case 2:
//LiDisplay_updateElement(0, 2, 1, 0, String(666));
LiDisplay_updateElement(0, 0, 0, 1, String(SoC_getBatteryStateNow_percent()));
break;
LiDisplayElementToUpdate += 1;
if (LiDisplayElementToUpdate > 2) {
uint8_t updateAttempts = 0;
do
if( (++LiDisplayElementToUpdate) > LIDISPLAYUPDATE_MAX_VALUE ) { LiDisplayElementToUpdate = 1; } //reset to first element
updateAttempts++;
} while( (lcd_updateValue(LiDisplayElementToUpdate) == SCREEN_DIDNT_UPDATE) && (updateAttempts < MAX_LIDISPLAYUPDATE_ATTEMPTS) );
#endif
uint8_t LiDisplay_bytesAvailableForWrite(void)
return Serial1.availableForWrite();
uint8_t LiDisplay_writeByte(uint8_t data)
Serial1.write(data);
return data;
uint8_t LiDisplay_readByte(void)
return Serial1.read();
uint8_t LiDisplay_bytesAvailableToRead()
return Serial1.available();
