1 - 2 of 2 Posts
A couple of days ago, I was leaving my driveway, I started the car, and selected reverse. Then Instead of driving, I turned the car off. I started the car again and went on my way, but later realizing that the little green lights on the gear selector does not go off showing reverse.
Anyone have an idea off how to fix this?
Unplug the sensor from the harness, then use your ohmmeter and connect to the two contacts on the sensor. when out of reverse it should show no mybkexperience continuity, when in reverse it should show a low ohm reading, indicating a good switch. ( I may have this reversed, but either way, it should be different ohm readings when it is in vs. out of reverse.
1 - 2 of 2 Posts
