Blink code links
My error there. I lost the original files and with them the links to the original spreadsheet, when I misunderstood how googledrive synced files.
When I replaced pdf files I had to redo the links.
Hopefully the spreadsheet and info behind it should be back up and safe.
_____________________________
[del][testing]
15.06.18
This should do it:
BLINK CODE LINKS+
https://docs.google.com/spreadsheets/d/1bLUyuFXWywH0PIzTXYtT6UprBNkOtjnWh5PFKjDFylA/pubhtm
EDIT: TEST HTML LIST:
OBDII CODE DTC TOP 20 HITS
Here's a googledrive HTML published spreadsheet of the OBDII CODE 20 DTC TOP HITS
https://docs.google.com/spreadsheets/d/1bLUyuFXWywH0PIzTXYtT6UprBNkOtjnWh5PFKjDFylA/pubhtml?gid=1288120291&single=true
It was formed up to give a coarse but measured perspective on the general percentage of specific codes that are thrown on the first generation ZE1 Insights as reported on InsightCentral.net
Searched via google: 'site:insightcentral.net "PXXXX" ' on google.
Some culling of data was performed for wrong entries, transpositions, and various code reader errors and/or typos.
Results in ranking are expressed as percentages [%] of all p-code occurrences found in posts within the gen-1 forum only. IMA issues top the list over the long term.
The web search list is comprehensive but not exhaustive as the values don't represent actual DTC fault occurrences nor the precise distribution of faults reported in real cars. It may however give a rough indication of the preponderant code issues experienced and expressed by forum members.
For anyone wishing a list of all gen-1 dtc codes by number of [-code posts can be found here:
https://docs.google.com/spreadsheets/d/1bLUyuFXWywH0PIzTXYtT6UprBNkOtjnWh5PFKjDFylA/pubhtml?gid=523260097&single=true
Top 20 DTC P-Code HITS on Forum
test: dtc frequency reported in posts c.15.06.20
TOP 20 DTC P-CODE HITS ON FORUM
P1447 21.47% -77 00-04 Battery Module Deterioration see BATTERY MODULE DETERIORATION pg. 150 IMA SYSTEM pg. 150
P1449 17.76% - not sorted by specific blink code
-72 00-04 Battery Module Overheating P1449 (72) Battery Module Overheating.pdf IMA SYSTEM pg. 110
-73 00-04 Battery Cell Overheating P1449 (73) Battery Cell Overheating.pdf IMA SYSTEM pg. 135
-74 00-04 Battery Module Individual Voltage Input Deviation P1449 (74) Battery Module Individual Voltage Input Deviation.pdf IMA SYSTEM pg. 149, 219
-78 00-04 Battery Module Deterioration P1449 (7 Battery Module Deterioration.pdf IMA SYSTEM pg. 111
P0420 12.42%
67 N 00-05 Y 06 Catalyst System Efficiency BeLow Threshold P0420 Catalyst System Efficiency Below Threshold (M:T).pdf Catalytic Converter
P1568 3.40%
-66 00-04 Battery Module Individual Voltage Input Problem P1568 (66) Battery Module Individual Voltage Input Problem.pdf IMA System pg.194
-67 00-04 Battery Module Temperature Signal Circuit Problem P1568 (67) Battery Module Temperature Signal Circuit Problem.pdf IMA System pg.112
-70 00-04 Battery Cell Temperature Signal Circuit Problem P1568 (70) Battery Cell Temperature Signal Circuit Problem.pdf IMA System pg.196
P1576 3.09%
-10 00-04 Motor Drive Module (MDM) Voltage Signal Circuit LOW Input P1576 (10) Motor Drive Module (MDM) Voltage Signal Circuit Low Input.pdf IMA System pg.225
-11 00-04 Motor Drive Module (MDM) Voltage Signal Circuit HIGH Input P1576 (11) Motor Drive Module (MDM) Voltage Signal Circuit High Input.pdf IMA System pg.234
-12 00-04 Motor Drive Module (MDM) Voltage Problem P1576 (12) Motor Drive Module (MDM) Voltage Problem.pdf IMA System
P1600 2.96%
69 NO IMA System Malfunction P1600 IMA System Malfunction.pdf IMA System
P0134 2.87% 41 NO Air/Fuel Ratio (A/F) Sensor (Sensor 1) No Activity Detected P0134 Air:Fuel Ratio (A:F) Sensor (Sensor 1) No Activity Detected.pdf Fuel And Emission
P1164 1.84%
61 01-03 YES Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/Performance P1164 Air:Fuel Ratio (A:F) Sensor (Sensor 1) Range: Performance Problem.pdf Fuel And Emission
P1420 1.38%
105 00-03 YES NOx Adsorptive Catalyst System Efficiency BeLow Threshold P1420 NOX Adsorptive Three Way Catalyst System Efficiency Below Threshold (M:T).pdf Catalytic Converter
P1166 1.20%
41 00-01 NO Heated Oxygen Sensor 1 (Primary HO2S) Heater Circuit Malfunction P1166 Air:Fuel Ratio (A:F) Sensor (Sensor 1) Heater System Electrical Problem (CVT).pdf Fuel And Emission
P1162 1.11% 48 00-01 NO Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response A/F sensor Fuel And Emission
P0A7F 1.07%
-78 05-06 Battery Module Deterioration see: P1449 (7 Battery Module Deterioration.pdf IMA SYSTEM pg. 111
P1565 1.04%
-42 00-04 Motor Commutation Signal Problem P1565 (42) Motor Commutation Signal Problem.pdf IMA System pg.185
P1586 0.96%
-23 Motor Power Inverter (MPI) Module Current Signal/Battery Current Signal Circuit Problem P1586 (23) Motor Power Inverter (MPI) Module Current Signal: Battery Current Signal Circuit Problem.pdf IMA System pg.289
P1601 0.89%
69 NO IMA System Malfunction See: P1600 [69] IMA System Malfunction.pdf IMA System
P1648 0.87%
-64 Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem P1648 (64) Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem.pdf IMA System pg.87
P1648 -75 Motor Control Module (MCM) Communication Signal Circuit Problem P1648 (75) Motor Control Module (MCM) Communication Signal Circuit Problem.pdf IMA System pg.290
P1444 0.84%
-59 00-04 High Voltage Short Circuit (see HIGH VOLTAGE SHORT CIRCUIT pg.114; also P0AA6 [59]) IMA SYSTEM pg. 114
P0303 0.82%
73 YES No. 3 Cylinder Misfire P0303 No. 3 Cylinder Misfire.pdf IGNITION SYSTEM
P2000 0.80%
04-06 NOx Absorptive Catalyst System Below Efficientcy see: P0420 Catalyst System Efficiency Below Threshold (M:T).pdf Catalytic ConverterP1447 21.47% -77 00-04 Battery Module Deterioration see BATTERY MODULE DETERIORATION pg. 150 IMA SYSTEM pg. 150
P1449 17.76%
P0420 12.42%
P1568 3.40%
P1576 3.09%
P1600 2.96%
P0134 2.87%
P1164 1.84%
P1420 1.38% 105 00-03 YES NOx Adsorptive Catalyst System Efficiency BeLow Threshold P1420 NOX Adsorptive Three Way Catalyst System Efficiency Below Threshold (M:T).pdf Catalytic Converter
P1166 1.20%
P1162 1.11%
P0A7F 1.07%
P1565 1.04%
P1586 0.96%
P1601 0.89%
P1648 0.87%
P1444 0.84%
P0303 0.82%
P2000 0.80%
