Back story: Dealing with an ailing battery 12v disconnect about three times in the past two months. Recently the SRS (airbag) light came on. I suspect the seat belt might be throwing the light, as I am dealing with the wet seat belt problem.
Today:
I was trying to jumper the OBDII port to get flash codes. I was doing this per Insight - MIMA Honda Insight Modified Integrated Motor Assist. I got a slight spark when completing the jump. When I started up I got no flash codes. I then shut down and unplugged the jumper and put my scangauge back in. No Power.
Turned the car on ... no power to scanguage. I started the car, no power to the scanguage and the SOC was at 0 and read charge status. (The battery was previously almost full.) The car idles and charges and in about three or four minutes the charge reads as full again.
I did some digging here and found the Meter fuse could be the problem. Visual inspection of the fuse it looked fine but I replaced it anyway. Still no power to the OBDII and 0 SOC. I can however shut the car off for short periods and the SOC will remain but after, I'm guessing, 5 minutes the SOC will read 0 again.
Possible messup:
My jumper was made of loose fitting (to the OBDII port) breadboard jumper cables and a breadboard. I suppose its possible I effectively jumped the wrong wires by making a connection across different wires inside the OBDII connector. I did put them in the right holes but I'm not sure what the inside of the connector is like so if there aren't channels for individual contacts I could have crossed over to another contact.
Questions:
Are there other fuses I should check?
Have I fried my OBDII?
Why was it so hard (12v disconnect) to reset my IMA light and now its acting as if I reset it just by turning the car off for a few minutes?
Any help is appreciated.
I'm off to check my IMA fuses before it gets dark.
-Kirk
05 CVT Insight.
Today:
Possible messup:
Questions:
-Kirk
05 CVT Insight.
