1 - 10 of 10 Posts
Does anyone have any idea at what point the low fuel light comes on? I usually take mine all the way down till it comes on and then fill up, but I'm afraid to go too long... I looked in the manual and it doesn't make any references. My old Ford Ranger comes on at 2 gallons/50 miles left.
Anyone know?
Thanks! :)
On my first tank of gas, the low level light came on with one bar still showing on the gauge. I immediately fueled the car and it took 9.6 gallons.
I stopped when the pump first clicked off, no topping off.
Regards,
low fuel light
Mine usually comes on when there are two bars left. I filled up the last time as soon as it can on and it took 8.4 Gallons. I haven't tested how far I can go but if it has a 10.5 gal tank I still had about 2 gallons left and that is about another 100 miles... BUT like I said I haven't and probably won't test it.
Jerry :)
G
Hi All:
___When the Low Fuel Light comes on in my Insight, I have between 85 and 105 miles left depending on temps and the FE I will receive over the rest of the tank. About a gallon give or take a few tenths.
___Good Luck
___Wayne R. Gerdes
___[email:38jtrrx7][email protected][/email:38jtrrx7]
I've driven...
...about 20 miles with the light on in my CVT. That time the tank took 9.87 gallons. In retrospect this was right before the car drove sluggish on my commute for a few days (and I posted about it), so I bet I was close.
Tire pressure is 40 psi on all four corners.
Oh! Threadjack--filled up yesterday and guess what--all four valves were exposed! May be the only time that happens.
Empirical research
Summertime last year, temps in the 90s at 8-8:30pm (hey, it's Texas)... sun about to set... average MPG ~54 @ highway crusing, 65-70mph, when the low fuel light pops on. Had just passed an exit, so I drove on for 65 excruciating miles before a fill-up (I did the prudent thing and dropped to ~60mph cruise, to extend range). Longest ~hour of my life. Found a station, managed to stop the bleeding on most of my bitten fingernails and wiped the driver's seat dry :lol: , filled up with 11.2 gallons (!) before it clicked off on its own. I don't continue to fill up once the pump stops automatically... but I might have been able to pump a cupful or two more, who knows... not worth messing up the overflow gadget. My Beloved rightfully called me an Idiot, won't push my luck like that again... :roll:
Discussion Starter · #8 ·
I guess to sort of answer my own question...
Yesterday I was driving, 2 bars on the fuel gauge, no low fuel light. Got out of the car for 1.5 hours, and when I got back in, there were NO bars on the fuel gauge and the low fuel light was on. Started driving to the gas station, as the engine warmed up, 1 bar came up on the fuel gauge. When I filled up, it took 9.6 gallons.
That was scary seeing NO bars when there had been 2! :shock:
I think mine comes on when it drops from 2 to 1 bar of fuel. I'm pretty sure I've watched it come on there. Then, if I keep driving, it will drop to 0 bars of fuel, which is a bit scary. I think I can get about a gallon's worth of driving done after the low fuel light goes on.
I thought I remembered that the manual says what's up with the low fuel light. I'm headed to the bank; maybe I can read while waiting in line.
1 - 10 of 10 Posts
