Hey guys, I ran into an issue.
Jacqueline citrus has an aftermarket cat that the previous owner put in. It looks a little bit longer and the normal 2000 oxygen sensor will not reach. What should I do? Should I be using the normal sensor with this aftermarket cat in the first place? Can I move the adapter socket or Is there an off-the-shelf lengthening adapter?
The current oxygen sensor keeps pulling loose because it's so tight and I bought the proper replacement year 2000 NTK replacement but it doesn't look to be any longer.
