Well, for fun I slid my lithium modules into my test pack and ran some test wires to prove it fits and get some ideas for amount of wiring needed.
This is a 48s setup.
12s in bay #1
18s in bay #2
18s in bay #3
Didn't take long to do.
I went slow and followed John's video.
While the video isn't concise, you can glean everything you need to know.
My pack is fine for looking at and maybe a very light drive around the block, but it is not correct for many, many reasons. (I started the list below and easily found 5*)
And since there really isn't any BCM input/output communication with the car, it actually can't fully work in the car, but it's cool to see none the less.
Here's more discussion fleshing out the hardware/software side of this project that is still in progress.
www.insightcentral.net
These are modules that are from 2018/2019 Honda Accord hybrid lithium Battery packs. Same modules are found in the 2019 Honda Insight as well.
* Problems with mock up. Don't do it like this!
Wrong sized wire
Wrong type of wire
Wires not properly run through the case
Wires not protected with sheathing
Modules not secured in case
12s in bay #1
18s in bay #2
18s in bay #3
G1 Honda Insight Lithium BMS Discussion
@retepsnikrep and I are considering designing a simple battery management system that supports Honda's 3rd generation Insight lithium battery packs. We've discovered that these packs mechanically fit in the G1's OEM IMA battery bay, which makes them an IDEAL candidate for simple lithium...
Wrong sized wire
Wrong type of wire
