Hi Guys
My 2000 Insight manual transmission has developed a failed input shaft ball bearing.It sounds like a spalled outer/inner race.Was only making noise in 1st gear under a load.Getting worst now,also 2nd gear now and pops out of 5th when no load is on it in over drive.After the bearing failure to reduce the noise i changed out the Honda MTL to a 100% synthetic Hypoid gear lube,noise was reduced substantial-with no diference in shift quality.
With hindsite should have had the synthetic hypoid oil in there all along,maybe the ball bearing would not have failed.
I have used the Honda MTL in SAAB manual transmission(transaxeles) with excellent results and shift qualities in those gearboxes that use a engine oil as the recommended lube in the transaxels.
Does anbody have any leeds on a used Insight manual transaxel??????
If so PLEASE post here,i have a leed to a unit in Maine.
Thanks Guy
Ronny
Thanks Guy
Ronny
