2001 Insight 5-speed tranny issue. Very stiif shifting, now won't budge:
225,000 miles. Never any problems with this tranny, no grind ever. Tranny fluid changed every 50,000 miles for good luck. About 3 weeks ago it became a little tricky to get into 5th gear, then soon tricky to get into other gears, had to wiggle and force the gearshift to get it into correct gear. Then about a week ago became very, very stiff and almost impossible to get into gear, but still no noises of any sort. Now I cannot budge the gearshift lever into any gear. No noises, no grinding, just won't budge. Checked fluid levels. Brake Master cylinder was a little low. Topped that up. The other which I assume is the clutch hydraulic master cylinder reservoir was full. After topping up brake master cylinder started car and pumped clutch peddle many, many times. No help, still cannot budge shift lever. Help!
