This is the voltage on all pin of TA8903SN at the first time only 12V is applied on VBU
then I add 12V on the input of the regulator that generate VCC
then I removed the 12V on the input of the regulator that generate VCC to let only 12V like it was at my first mesurement
| first power with only 12V at B10 (VBU) | with only 12V at B10 (VBU) and VCC = 5V | power with only 12V at B10 (VBU) after vcc shut down |
IC22 TA8903SN pin 1 | 0V | 4.95V | 3.4V |
C22 TA8903SN pin 2 | 0V | 5V | 0V |
C22 TA8903SN pin 3 | 0V | 4.57V | 3.2V |
C22 TA8903SN pin 4 | 0V | 4.96V | 3.46V |
C22 TA8903SN pin 5 | gnd | gnd | gnd |
C22 TA8903SN pin 6 | gnd | gnd | gnd |
C22 TA8903SN pin 7 | 0V | 4.78V | 0V |
C22 TA8903SN pin 8 | 0V | 4.21V | 0V |
C22 TA8903SN pin 9 | 12V | 11.99V | 11.47V |
C22 TA8903SN pin 10 | 0V | 0.41V | 3.03V |
C22 TA8903SN pin 11 | 0V | 2.513V | 0V |
C22 TA8903SN pin 12 | 0V | 0.022V | 3.46V |
IC3 - 11 | 0V | 0V | 3.46V |
IC3 - 6 | 0V | 5V | 3.4V |
IC3 - 3 | 0V | 0V | 0V |
With these measurements, I believe I have identified the pin-out of TA8903SN
pin 1 is an output, there is 4.95V when VCC is present on pin 2 otherwise there is 3.3V generated from pin 9
pin 2 is VCC input
pin 3 is normaly high, I'm not sure when it goes down to 0, maybe for a short moment when VCC is applied but I'm not sure.
pin 4 dont know what is it
pin 5 gnd
pin 6 gnd
pin 7 maybe an RC timer to do a reset when VCC goes up
pin 8 generate a power fail warning 4.2V when pin 2 is high and 0V when pin 2 is low
pin 9 Backup Power
pin 10 transistor driver
pin 11 input VCC/2 - I dont know if it is true only when VCC is 5V but when input VCC is 0V pin 11 is at 0V
pin 12 low when 2 volgate source are there high when ignition is off and only one supply source present.
by these measurements, I can say that the CPU of the MCM is always powered
and IC22 and the components it powers consumes the following current: (12V - 11.47V) / 2200ohm = 0.24 mA when ignition is off
