1 - 9 of 9 Posts
I just called around to a bunch of mechanics around Phoenix (even the mechanics that specialize in Honda, like Hon-amotive), and no one will touch my Insight. Anyone from the area have a local mechanic they can recommend that will service hybrids? I'm willing to drive to any place in the valley if they do good work.
Thanks!
-Dan
Insight in AZ
I have had the same issue... I finally took apart the entire EGR valve, intake and gaskets and cleaned and replaced them. Bell Honda said that had a factory trained staff but I took it in for an oil change (when I first got it) and they did not even know what oil it required. So, since then I have been looking, that was 2 years ago. I finally bought the shop maint and electrical manuals. Pretty easy little car to work on (so far).
If you find anyone, please let me know (just in case).
Bell Honda sells their parts 25% off to move volume and frequently list on ebay. Just ask for Ryan.
I cant say I have ever visited a dealer that knew or had the level of experience or knowledge I wanted in a mechanic. I came close at a benz dealer as the mechanic I requested owned a car just like mines, a 240d.
I plan on doing the stuff myself like oil changes and leaving them to do the factory or warranty stuff.
I eventually found this guy: Hybrid Auto Service
I took a bit of a gamble because he had never actually worked on an Insight before. But he's been a mechanic for a couple of decades and he was pretty familiar with the Prius, so I figured it was worth the risk. To be honest, I figured anything was better than bringing it in to the dealership.
I think it worked out pretty well. He was very sincere and honest and gave me a pretty deep discount for letting him learn on my car. For $1000, I got a new cat, spark plugs, coolant flush, transmission fluid, and he cleaned and reseated my valves. It's been 2 days and the car's running great, so I'll give him my recommendation.
-Dan
"he cleaned and reseated my valves"......................Don't you mean "checked and adjusted"?
Did he give you the old parts he replaced?
Just curious....Willie
Discussion Starter · #6 ·
Not sure I understand the difference between those two sentences.
No he didn't, although I don't think I would have wanted them even if he offered.
2001 Honda Insight
Reviving! I'm looking for a Phoenix mechanic who works on G1 Insights.
I actually need a rattling issue checked, right now.
HybridRevolt is my local go to, but is currently unavailable.
Everyone is afraid to touch Hybrids, they are afraid of Toyota's really. Mechanics do not realize how simple the Insights are. I just tell them it is a normal Honda civic type engine minus a cylinder, and show them how to safely shut off the batteries. Unless it is a hybrid battery?/IMA issue any mechanic can work on an Insight. I even bring a pdf copy of the service manual for whatever the problem is.
1 - 9 of 9 Posts
