21 - 37 of 37 Posts
Banned
So, since it doesn't look like anyone's tried the Mobile 1 'high mileage' oil, what do most Insight drivers use? Mobil 1 0-20 'Advanced Fuel Economy'? Back when I drove a Miata and frequented a Miata forum, seemed like most everyone there used or recommended Mobil 1. So I guess I simply continued to use Mobil 1 when I got the Insight (the '0-20 advanced mpg'). But I guess I've never actually seen Insight drivers recommend that, at least not all the time...
Oh, similar applies to the filter: the Miata drivers usually used Napa Gold, and the WIX regular is the same as the Napa Gold, so I continued to use that. Plus, if you look at filters side by side, you can see that the Napa Gold and WIX filters are a lot better made than, say, the 'Microgaurd' or other cheapies (though as I mentioned earlier, I sometimes use the Microguard). I also have used the Miata numbered filter, which fits on the Insight but is a little bigger (I think it's 1365 rather than 1356).
0w20 Mobil 1 advanced fuel economy is what I've always used. As for filters, I am not picky at all. I prefer FRAM tough guard filters, purely because of the anti-slip coating on the end that makes installing/removing them a breeze. Are there technically better filters? Sure, but I don't think it makes any difference.
Ive "heard" from people who cut open filters that many times the fram seam is not glued correctly allowing a gaping hole of unfiltered oil thats good enough reason not to use fram
Show some pics of the cutaway filter!
Banned
Idk, I have used Fram filters in everything I've owned since 1996, no issues, ever.
I think maybe since they are the most ubiquitous brand, and the most popular, we just see weird failures online more often.
So has anyone seen improvements in MPG's by switching to Advanced Fuel Economy?
I went to Wal-Mart today and saw both versions on the shelf. I ended up getting the high mileage extended performance because I plan on only changing oil 1x/year from now on.
Discussion Starter #32
^ Funny, I had to blink twice - because I couldn't believe I actually started an 'oil' thread... Can't answer your specific question, but I never did see any difference when I tried the high mileage stuff - in terms of oil consumption. I switched back to the 'advanced', but in general I don't really care. If one were on sale and the other weren't I'd probably get the sale item.
My application is not the same - I have a K24 engine from a TSX in my car now. I'm running 0w20 AFE rather than the recommended 5w30 and have been able to squeeze a couple of 70mpg trips out of an engine with literally 5x the horsepower to the wheels.
I don't have an apples to apples comparison with standard 0w20 or even 5w30, but I did not reach these economy numbers last year when I was running a different oil.
That is awesome. I just saw in your sig the thread about the K24 conversion. I love this car so far but the low engine power really sucks. Good to know that you are seeing better MPG's with the AFE oil even though you have a different engine.
You may be able to generate 5 times the power but I bet you are putting out pretty much the same power as the stock engine when you are getting those 70 MPG numbers.
  • Like
Reactions: kennysmith
21 - 37 of 37 Posts
