1 - 19 of 19 Posts
Introduction
12V system voltage has been an issue for me trying to run different 12V battery types. With my 12V NiMH setup, normal DCDC output voltage is a tad on the low side, and wanting to try a lithium-titanate based battery (LTO), output voltage is on the high side. So some weeks ago I dug into settling this DCDC output business once and for all - and I think I'm there. I posed some questions in other threads over those weeks - I've linked to those at the bottom of this post.
Here I think it's worthwhile to briefly document what I came up with, a few different options, the output range, etc. This should be useful for people who want to try different battery types, but also, a lot of folks report 12V battery issues at IC, so being able to adjust DCDC output voltage a little higher might be useful to them as well. Doing so is pretty easy and cheap, especially if you're not having to spend the time figuring out how to do it...
In a nut shell, normal DCDC output voltage is 13.8V when the car's warmed up, with switching into 'low power mode' at various times, such as minimal accessory usage, down to about 12.2V. The "WHT/GRN" "DVC" wire controls automatic toggling into low power mode; Mudder has advocated snipping that wire if you don't like that behavior. With my NiMH cells I've kept that in-tact because some cycling is better for my cells.
The RED/YEL "DVCT" wire adjusts DCDC voltage supposedly based on engine coolant temp (ECT). Not sure to what extent that's true, as I didn't see an obvious one-to-one relationship between ECT and the PWM signal (pulse-width modulation) at DVCT - but I wasn't watching very closely. In general, it doesn't make a whole lot of sense to adjust output voltage based on engine coolant temp, as the correlation between ECT and battery temperature is... not very tight. In the end, at least in a temperate climate, DCDC output voltage is a tad higher at cold start, but once the engine is warmed up, output voltage is as low as it can go via DVCT. And that's the end of DVCT's usefulness. There's a standard voltage adjustment scheme for lead acid batteries vs. temperature; it seems like DVCT is some kind of proxy for implementing that scheme.
'Methods' and 'Results'
My mods here involve DVCT. As Mudder first pointed out, DVCT is a 10Hz 0-5V PWM signal, with a duty cycle ranging between 10% and 90%. When duty is low, DCDC output voltage is high, and when duty is high, output voltage is low. Here are voltages I measured at 12V battery vs. PWM duties:
100, 13.85V
90, 13.85V
80, 13.91
70, 14.02
60, 14.12
50, 14.21
40, 14.30
30, 14.38
20, 14.45
10, 14.51
0, 15.13
A duty of zero is equivalent to grounding the DVCT wire coming out of the DCDC. Mudder described this as something like faulting out of range, and the DCDC output voltage goes to its max output.
Unfortunately, I discovered that the lowest output voltage is still on the high side for my LTO 12V battery. I'll try one anyway, but I may have to figure out something else. As far as DVCT is concerned vis-a-vis my LTO 12V, the only thing I can do and should do is detach the wire at either the DCDC connector or the ECM. This will limit DCDC output voltage to a max of 13.85V (DVCT is pulled high to 5V in the DCDC converter).
So, as you can probably see, the basic thing we're trying to do is bypass the PWM signal going from the ECM to the DCDC, instead sending our own programmable/adjustable PWM signal. If you wanted to keep the OEM putated engine coolant temp-based adjustments, you could do that, too, say on top of whatever overall voltage level adjustment you want. But I didn't explore that. You'd have to use an Arduino or similar and create a program that uses the ECM signal as input, alters it based on your programming, then sends your altered values to the DCDC. This is more or less the original idea Mudder posed like a year or two ago [edit: more like 3 years ago, how time flies]...
I tried two different devices for the simple bypass: I bought an inexpensive PWM signal generator ($6.50 at Amazon) and I bought some Arduino Pro Minis (clones, 5 for $17). I also needed wire and header pins and stuff. I hooked-up the signal generator in the IMA compartment and in the cabin by the ECM, both locations worked fine. I really like the signal generator because it has buttons on it that allowed me to adjust the duty cycle right there. Made it easy to change duty and record DCDC voltage output. I tried the Pro Mini only in the cabin by the ECM and thus far I've only checked that a 40% duty cycle corresponds to the same voltage that 40% with PWM device produced. This was my first foray into Arduino and, I gotta say, it took a lot of work to figure out how to make it do something that in the end is asinine simple.
PWM Signal Generator in IMA Compartment
At first I powered the PWM signal generator with a buck converter running off of car 12V power, 'bucked' to 5V (the output voltage of this PWM device is the same as input voltage), but that turned out to be unnecessary. In the IMA compartment I simply tapped into the same power and ground that the BCM Interceptor uses (thanks to Jime for that suggestion). Rather than at the MCM, though, I tapped into those wires at the 'Junction Board 16 - Lt BLU' connector, across from the DCDC, GRN/WHT Pin 3 VCC7 +5V, and RED/YEL Pin 11 SG4 (signal ground 4). It's easy to pull out the metal terminal for DVCT RED/YEL at DCDC connector, disconnecting DVCT from the ECM. You then connect the + PWM output to the DVCT pin that leads to the DCDC and tape-up the ECM side. The - PWM output goes to WHT/BLU SG10 on that same connector.
Here's an image of that setup. The PWM device has two PWM outputs, but we only need one here. The buttons on the bottom allow you to set the frequency and duty cycle.
83112
PWM Signal Generator in cabin, by ECM
The same setup - but in the cabin, by the ECM - relies on ECM Connector C (BLUE) C28 YEL/BLU VCC2 for +5V and C18 GRN/BLK (SG2) for both the power ground and the signal ground. I'm not sure about the wisdom of having both the device power and signal using the same ground, but it works. DVCT RED/YEL is on Connector A (GREY), A7. As with the DCDC connector, here it's very easy to pull the DVCT terminal out of the ECM connector and unwind some of the wire from the rest of the loom, so you have a decent amount of slack in the DVCT wire plus a small female terminal that actually fits pretty well on the standard header pins you'd solder to a PCB... In my car, I had already tapped into C28 and C18 when I installed one of Peter's 'boost boxes' - so I have a pigtail with a Molex connector accessing those pins, and here I tapped into that connector.
Here's an image of that setup, PWM device in cabin by ECM. Sorry it's not the greatest quality. You can see that 90% duty shows up as 13.9V on my OBDIIC&C '12v' parameter.
83113
Arduino Pro Mini clone in cabin, by ECM
Using an Arduino Pro Mini, or similar Arduino devices, turned out to be very simple in the end. Some of the hardest parts for me included just figuring out how to program, the conventions, figuring out how to change the default PWM frequency, plus the Pro Mini doesn't come with a built-in USB connection to upload programs, you have to add that. But, I only had to solder header pins to connect a USB break-out module plus one pin for the PWM output. I chose the Pro Mini mainly because I like its small size and the idea that you only install the pins you need... Plus they're so inexpensive.
I installed Pro Mini in the cabin by the ECM, using the same power connections and DVCT wire as the PWM setup. Here are a couple images. DVCT RED/YEL is connected on pin 10, behind the board.
83114
This image shows the setup when you're uploading a program to Pro Mini. The red thing is a "TinySine Micro USB FTDI Basic Breakout Module for Arduino," connected to a micro USB cable, which is connected to my PC.
83115
Here's the 'code' I used to program Pro Mini to do the PWM thing:
Code:
#include <TimerOne.h>
    // Makes TimerOne library functionality available to Arduino IDE
void setup() {
  Timer1.initialize(100000);
    // Initializes Timer1 to overflow in 100000 microsecond periods, 1/period=frequency
    // 'DVCT' is 10Hz, 10Hz is 1/10 second period, which = 0.1 X 1,000,000 in microseconds
  Timer1.pwm(10, 410);
    // Enables PWM on pin 10 with 40% duty cycle (0.4 X 1024)
    // This function expects 10 bit value for duty cycle, i.e. 0 for 0% to 1024 for 100%
    // 'DVCT' adj range 10% to 90% (14.50V to 13.85V output), 0% faults to 15.10V
void loop() {
The biggest hurdle here was figuring out that Pro Mini and other Arduinos don't have native commands to set PWM frequency. If you use analogWrite - the normal way to do PWM - you're stuck with a default frequency. So, either you can use commands (functions) that manipulate the onboard timers to get the right frequency or you can use a 'library' that has already packaged that stuff. I'm using the "TimerOne" library here. But once you get over all that, it's obviously super simple to change the frequency and duty.
One drawback with using Pro Mini/other Arduino, in this simple form, is that you'd have to reprogram different duties to get different DCDC output voltages, so if you don't know the exact voltage you want you'd have to program with a given duty cycle, install, try and measure output voltage, then remove and re-program with a different duty if the output voltage isn't what you want. I'm thinking I might try to add a trim pot to make the duty adjustable at the device, installed. The Arduino would factor-in the pot position when calculating the correct duty cycle...
Conclusion
Rock on...
Here are some links to the devices and stuff I purchased:
PWM device: https://www.amazon.com/gp/product/B07QNYMNGK/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
USB programming thing: https://www.amazon.com/gp/product/B00N4MCS1A/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Micro USB cable: https://www.amazon.com/gp/product/B01JPDTZXK/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Pro Minis: https://www.amazon.com/gp/product/B015MGHLNA/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Misc. header pins and cable: https://www.amazon.com/gp/product/B01G0I0ZZK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Weller WE1010NA soldering station - figured it was time to move up from my probably 30 year-old $19 special: https://www.amazon.com/gp/product/B077JDGY1J/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
60/40 fine solder: https://www.amazon.com/gp/product/B071WQ9X5K/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Here are some links to threads/posts where I asked questions during this project, can provide some background/genesis if needed:
I attached a pdf version of this post which might make it easier to print and read, fits on 5 pages.
Have a look at something like the DFRobot Beetle, its a very small and cheap Arduino clone with very limited number of IO, but 4 PWM outputs. I have a couple of thumbduino boards which are a similar type of affair. the 4 PWM outputs are a common thing on small boards now for running RGBW LED lighting.
Discussion Starter · #4 · (Edited)
^Hmm, that looks like it'd do the trick, but I'm seeing like $10-20 for one, whereas the ProMinis I bought were 5 for only $17. Other than that, I'm thinking the Nanos might be good, since they have built-in USB and one wouldn't have to deal with adding that, I'm seeing prices similar to the ProMinis, maybe a bit less...
But really, if one wanted to 'just get the mod done', the PWM device seems like it'd be the quickest and easiest - and only about $7. Using Arduino is more about tinkering/learning, or maybe if one already has some laying around, maybe if one wants to try other things along with the DCDC mod (like maybe controlling the low power mode on the 'WHT/GRN' wire, etc.)...
At that price I'm guessing they are not genuine Arduino boards but non name Chinese clones. Some of these are ok (I have some Elegoo ones that seem fine), in my experience they are a lot less tolerant to abuse and power voltage swing. I use them for proto work, but I'd put something of higher quality in my car for long term use (personally, YMMV and they could do you fine).
Discussion Starter · #6 ·
I'm looking for a little programming/device guidance.
I'd like to add a POT to my ProMini-based DCDC output voltage mod, that I can use to adjust PWM duty (which adjusts DCDC output V). I've compiled something that works, but in some sense it doesn't seem quite optimal...
The POT would be used to adjust PWM duty like a few times when the device is first installed. But after that you probably wouldn't change it at all - set it and forget it. Yet, the code I've got checks the POT all the time and changes PWM duty all the time based on POT position.
I noticed POT values change slightly from time to time, even though the knob hasn't been moved. Makes me think that, if you want to 'set and forget', having the program check the POT all the time and/or having it constantly resetting PWM might make the setting susceptible to noise, or whatever.
Does that makes sense, does it really matter?
I'm thinking some other code that relies on some kind of conditional statement might be better, or something that only intermittently checks the POT value and/or changes PWM, such as comparing to a stored value and if the value hasn't changed 'do nothing'... I guess the main thing is that it seems like PWM duty shouldn't be potentially changing all the time based on POT position; it should only change those few times you need it to, when you initially install the device. After that, 'just keep duty the same unless the POT is actually rotated'... Just don't know if my concern for 'noise or whatever' is valid or valid enough to justify making some more complicated code...
Here's my program as it stands. I have PWM changing the brightness of an LED here, so the parameters are different than what it'd be for changing DCDC voltage (for example, the period is a lot shorter for a higher frequency, so the LED doesn't just flicker)...
C++:
#include <TimerOne.h>  // Makes TimerOne library functionality available to Arduino IDE
const int POTPIN = A1;
int POTVAL = 0;
const int DVCT = 10;
void setup()
  pinMode(POTPIN, INPUT);
  pinMode(DVCT, OUTPUT);
  Timer1.initialize(8333);  // Initializes Timer1 to overflow in xxx microsecond periods, 1/period=frequency
  // 'DVCT' is 10Hz, 10Hz is 1/10 second period, = 0.1 X 1,000,000 in microseconds
  POTVAL = analogRead(POTPIN);   // values range from 0 to 1023
  Timer1.pwm(DVCT, POTVAL);   // Enables PWM on pin 10 with duty cycle based on pot position
  // function expects 10 bit value for duty, i.e. 0 for 0% to 1023 for 100%
  Serial.begin(9600);
void loop()
  POTVAL = analogRead(POTPIN); // might need delay or millis() after this or setPwmDuty?
  Timer1.setPwmDuty(DVCT, POTVAL);
  delay(250); // 250ms, 4 reads per second
  Serial.println(POTVAL);
I don't know anything about arduino code however.. Below is what I do in pic basic pro.
Save the PotValue between loops, and only change the PWM if PotValue has changed.
So add something like POTVALOLD = POTVAL after you set the Timer1 PWM.
Then after you get the new POTVAL from the next analog read compare it to the old value POTVALOLD.
Are they equal? Y/N
If N update PWM. (Only updates if it has changed)
If Y get next analog read. (Repeat until it changes)
Discussion Starter · #8 ·
^ Thanks for the input. That's along the lines of what I was thinking. It makes more sense conceptually. But, I'm not sure it would make any material, substantial difference if the program 1) checked the POT and changed PWM each time through the loop, or if it 2) checked the POT and only changed PWM if the value changed.
Like, if it checked the POT and the value didn't change, I don't think setting PWM to the same value, under method 1, would be much different than leaving it the same, under method 2. The command I'm using ('setPwmDuty') is supposed to be simple, have 'low overhead', and the whole program is simple, too... So it's not like I have to conserve space, computing power, or what-not. But in the scheme of things, I'd like to be creating stuff that makes the most sense, that, in the long run, would conserve space and all that, should I need it...
I'll have to think about it some more. There are other things I should implement as well, like setting range limits on the PWM (I should probably prevent the POT from setting a duty below 10%, unless POT is turned all the way down, for instance, which would then go to zero and DCDC output voltage would 'fault' to 15.1V, i.e. at 10%, output voltage is about 14.5V, but then it jumps to 15.1V at zero duty)...
If the value hasn't changed you do not set the pwm again.
You only change the pwm when the pot value changes.
Yes you could add further tests on the POT value and set defaults or ignore readings above/below set values etc.
All good practise for you.. ;)
Discussion Starter · #10 ·
That's what I said, isn't it?... I'm saying that whether you leave it the same (i.e. do not reset PWM) or reset PWM even though the value hasn't changed (i.e. reset PWM with the same value) - it probably doesn't make a real difference, in Arduino, with the command I'm using. I don't really know though, no experience...
True.
Discussion Starter · #11 · (Edited)
Want to quickly jot down an idea I have, before I forget, maybe come back to it later...
I pulled my stick-based NiMH 12V battery and the cells look pretty bad, balanced but voltages are really saggy, high IR. Based on some ongoing logging and such I've been doing with my IMA pack, and on my reconditioning experience and research in general, I'm pretty convinced that these cells need to be at least, not necessarily 'cycled', but dropped to a relatively low voltage once in a while to avoid voltage deterioration.
The type of usage/management the 12V battery sees in the Insight seems less than ideal. I've had my DCDC output voltage set to mostly 14.2V, I bumped it up to 14.5 a few weeks ago. My 'WHT/GRN' wire is in-tact, so 12V charging drops to 'low power mode' actually quite often, particularly because I use my IMA pack at low charge state (which seems to induce more 'low power mode' at the 12V)...
But, even with this toggling down to ~12.2V, it doesn't seem to be enough. Maybe. It could be other things I guess, like relatively hot underhood temps. That definitely wouldn't help. But I haven't really been using the car in extreme hot conditions, and I usually take precautions, such as opening the hood after a summer drive. So, the cells shouldn't have been getting too hot too frequently... Maybe a max of around 110F, <1% of the time?
So, the battery has been floated at about 14.2V, later to 14.5V, with low power mode enabling drops to about 12.2V, where the DCDC supplements power output, upholding about 12.2V at battery. When I discharged the cells on the bench, after pulling from car, I extracted a total of about 5400mAh - so the cells were charged to a pretty high absolute charge state. The saggy deterioration, however, meant that I could only discharge this much at low current - I got about only 1200mAh, maybe 1600mAh, at 6 amps, the rest at progressively lower discharge currents...
Anyhow, that idea: I'm thinking it might make some sense to use one of the Arduino Pro Minis I got, instead of the off-the-shelf PWM device, and program the ProMini with a variable PWM output, so variable voltage range, based on some sort of time metric. The idea is to utilize the full 13.85V to 14.5V DCDC output voltage range, to mix it up rather than keep it at one level all the time.
For example, maybe normally the output would be set to 14.2V, but occasionally, it'd toggle down to 13.85V for some duration, maybe at least a week, and then toggle up to 14.5V, again, for maybe a week, before settling back to 14.2V. This should allow the battery to see a wider charge state range. Might help long term battery health... I'm actually leaning toward lower voltages overall. In my car, with IMA pack, I can only sustain consistent performance and cycles/usage if I don't allow the pack to charge high. I've 'charged high' maybe 3 or 4 times over the past year or more, and every time I've done that I've seen saggy voltages creep in very fast, like within a week of daily usage... In order to bring performance back I've needed to bring the pack back down to near zero actual charge state and use the range roughly between 0 and 40%...
Perhaps usage between the low power mode 12.2V and the lowest programmable DCDC output allowed - 13.85V - would somewhat approximate this lower charge state usage. It can be really hard to say, voltages vis-a-vis charge state can be such a moving target with these cells...
Not sure what 'metric' I'd have to use for the "time" variable. If anyone has ideas please feel free to add them. I'd be using a ProMini and need to keep track of time over long durations, like the month+ time range. The device currently isn't powered with key OFF, so either it'd need to save the time before keying OFF or I'd need a constant power source... Etc etc.
"So, the battery has been floated at about 14.2V, later to 14.5V, with low power mode enabling drops to about 12.2V, where the DCDC supplements power output, upholding about 12.2V at battery."
^ Just thought of something, like this is the problem: At some point, voltages start to sag - yet the voltages cease to reflect the normal charge state. So I'm getting drops to 12.2V - in low power mode - but the drops are more a reflection of high IR or 'voltage depression', not low absolute charge state. The cells could be charged to say 5000mAh and see a voltage of 12.2V/10 cells=1.22V. With good cells you wouldn't see that kind of low voltage unless the load were high or the cells were near empty. So, these cells could stay at a high absolute charge state (i.e. ~5400/6500=83%) despite what seems like a relatively low voltage, i.e. 1.22V... That doesn't seem good.
hmm, maybe I should bump my cell count up to 11 cells instead of 10, where 12.2V/11=1.11V, so low power mode brings the voltages down low enough to see 'rejuvenation'...
On the higher side, 11 cells would mean, say, 13.85V/11=1.26V to 14.5V/11=1.318V. Both of these seem too low, like the battery wouldn't get charged enough, they definitely wouldn't at only 1.26V. Interestingly, 1.318V is the exact equilibrium voltage for these cells... I'm pretty sure you need at least something like 1.34V to get some charge in. On the other hand, I've never really experimented with trying to use the really low voltage range, like 1.1V to 1.32V, exclusively. I did do some low current charges to estimate charge state vs. voltage, a long time ago, let me see if I can dig that up...
-Charging from near empty at 3A to CV at 1.32V, down to 300mA, produced a charge of 700mAh
-Same thing to 1.36V produced a charge of 1800mAh
-Same thing to 1.40V produced a charge of 4200mAh
Based on these data, 11 cells is no good, wouldn't charge high enough. And, in general, it looks like the right 'float' voltage might be between 1.36V and 1.40V - that's a huge potential range of charge state. If varying the usage charge state window were the goal, a voltage around 1.38V (13.8V for 10-cell battery) seems like it should/would keep the battery charged anywhere between about 1800mAh and 4200mAh. It'd be kind of random, depend on varied driving circumstances, whether it'd be on the high side or the low side...
Could you solve this by simply making use of a normal 6cell stick pair, and basically have the sticks at low voltage per cell at all times? or is this bringing each cell too close to the recommended minimum?
Discussion Starter · #13 ·
If I'm understanding what "this" is, and if "making use of a normal 6cell stick pair" means using 12 cells, then no, the voltage range wouldn't be right vis-a-vis the range of output that can be done with the DCDC. For example, the max DCDC output is about 14.5V (15V is max, but then that's a bit too high for the 12V system, etal). So, 14.5V / 12 cells = 1.21V per cell. That's not charged at all.
I have been messing around a bit, changing the DCDC output voltage manually, such as from 13.85V to 14.5V and back, over 1 week or so intervals, but I haven't been able to tell if there's any difference, not via casual observations. I'd have to look at things more closely to be able to tell yet I'm not all that into this project.
I have noticed that my 12V stick-based battery (10 cells) is near empty when I set DCDC output to 13.85V. Not sure if that's because of a single cell or if the whole thing is simply not getting charged high enough. I swapped sticks no too long ago, and as I recall there was at least 1 or 2 cells that were on the edge in terms of relatively fast self discharge... So being near empty at 13.85V DCDC output could just be the result of 1 or more of these faster SD cells. I'd have to break things down and check it out on the bench, not something I'm jazzed to do at the moment... I can boost DCDC output voltage up to 14.5V or so (or actually only 14.2V or so), and at least for now that provides enough charge...
You nailed it. Exactly what I meant. so 6cell sticks utilized fully would basically render the capacity near zero, or at least close enough to be damaged if under a big load, like engine start.
Hmm. I still have my 8 Headway cells to make use of, in 4s2p
Discussion Starter · #15 · (Edited)
...so 6cell sticks utilized fully would basically render the capacity near zero, or at least close enough to be damaged if under a big load, like engine start.
The first part, not really the second part. The engine start load is pretty tiny. You have to have a really, really drained pack for the engine start load to, first, not work, but second, put much of a 'dent' in the pack. I don't think even a fully drained cell would suffer damage from the brief engine start load -- perhaps possibly, if it were allowed to happen repeatedly, but under normal circumstances I don't think it would be allowed...
Wait, on the other hand, we're (I'm) mixing apples and oranges: the 12V battery isn't used for starting... I'm thinking of IMA start. If you had IMA disabled and were starting with auxiliary starter?... Meh, it just wouldn't work, the battery would be too dead. You'd turn the key ON and the 12V battery voltage would plummet to nothing, with a merely ~80 watt load.
You have to have a pretty decently charged 10-cell NiMH 12V battery to work with the auxiliary starter. The cells themselves have to be pretty good, too, can't have cruddy, putzed-up, high resistance cells. The 12V starter load is at least 1000W, 130 amps and up. And it doesn't start the engine instantly like the IMA does. It's pretty substantial for a meager 6500 mAh Insight cell-based NiMH battery.
well, if it helps get an idea of starter loading, Ive used a $20 lawn tractor battery to start a high compression 1.5 liter 4cylinder in the cold. Did it just fine.
Id imagine the 1.0 3cyl is around 60-70% of the load, even if the starter is rated very similar to the civics.
I personally have never heard my engine starter working, even at negative *F temps. I think at some point, something went wrong with my Insight, and it uses the IMA pack all the time. It would explain the SoC depletion when cold, and the positive calibration that occurs, if I have to start the car, and go right away (within 45-60 seconds of startup), example running late for work. I still let it idle a minute though.
Discussion Starter · #17 ·
Not too long ago I swapped different NiMH cells into my 12V battery, generally better than what had been there. I've noticed that the charging power these cells endure - and that the DCDC puts out - can be quite huge.
With an OBDIIC&C you can see pack voltage, IMA current, and 12V system voltage, which can be used to calculate DCDC power output. When you go into autostop with DCDC in normal power mode (i.e. not low power ~12.2V), power is drawn from the IMA pack and IMA current goes negative, showing the drain. That power is powering the 12V system. If the 12V battery is discharged, some of that power is used to charge the 12V battery.
Knowing what the base load is, what the 12V system demands when the 12V battery is charged, you can tell how much charge the 12V battery is taking in. The base load in my car, with always-on driving lights, is about 1 amp at about 150V, or about 150W.
Thus, you can calculate what the DCDC is putting out and how much of that is charging the 12V battery.
With a somewhat discharged 12V NiMH battery, today I noted a peak of -5.5 amps at 150V. There was something like a few seconds of around 5-5.5 amps. That means the DCDC was putting out about 5.5A X 150V = 825W.
Since the 12V system base load is about 1 amp at 150V, or 150W, my 12V battery was charging at about 825W minus 150W = 675W.
I have my DCDC output voltage adjuster mod set to I think 14.2V at the moment, which means DCDC is programmed to try to hit 14.2V. Given that, the current rate that my 12V battery was seeing during this charge is: 675W/14.2V = 47.5A.
That's pretty high...
At some point I had wondered what impact an 'efficient' low IR or low ESR 12V battery would have on DCDC output. I had thought that the battery would take in a lot of power, that DCDC output would be high, etc., and that does seem to be the case... I'm not sure what the rated output of the DCDC is...
How much of that 12v amperage was the car system getting though? Not 100% of that was fed directly to the battery. The 12v stuff was using some of that too.
Discussion Starter · #19 ·
^ Right. As I said, the base load is about 150W. DCDC output total 825W minus 150W = 675W to 12V battery.
1 - 19 of 19 Posts
