hey all, im wondering if anyone has any tips on good, aerodynamic windshild wipers?
thanks
thanks
I second that. One day in a downpour on the highway, I was still using my intermittents when others had their wipers maxed out.HafNHaf said:rain-x. not the wipers, the windshield washer fluid. hardly ever use my wipers.
Having been inspired by talking to Alex (Albad) & seeing his G1 Insight I would like to share a few cumulative options that I have done to reduce wiper blade/arm drag:Installing the more aerodynamic wipers may help but it doesn't solve the problem that the wiper arms are exposed to the high speed air flow.
are they really aluminum? How can you tell. They seemed like normal metal ones to me when I took them out to clean.One thing I like about the I1 is all the touches.... and that includes the aluminium wiper arms.
Seems a shame to revert to 'normal' ones![]()
If they are attracted to a magnet, they're steel. Some stainless steels are only weakly attracted to a magnet, but we know they're not stainless steel.are they really aluminum? How can you tell.
The paint has flaked off due to the corrosion underneath, the corrosion is clearly aluminium oxide rather than rust. Aluminium is a normal metal..are they really aluminum? How can you tell. They seemed like normal metal ones to me when I took them out to clean.
Have you tested them with a magnet?The paint has flaked off due to the corrosion underneath, the corrosion is clearly aluminium oxide rather than rust. Aluminium is a normal metal..
UK car if that makes a difference I wonder?
It seems we were both partially correct: the upper & middle section of the wiper arm is magnetic i.e not aluminium but the short section next to the attachment nut is a much thicker metal section and non-magnetic. The first 2 pictures show the non-aluminium parts; the third shows the aluminium part.The paint has flaked off due to the corrosion underneath, the corrosion is clearly aluminium oxide rather than rust. Aluminium is a normal metal..![]()
