I have reason to believe that there is something wrong with my stock 2000 5-spd. No warning lights, but the true MPG is two less than the FCD (not lifetime MPG) and I heard that the FCD is acurate to +/- 0.1 MPG. However, this is not about troubleshooting my car.
I have a simple survey to collect MPG info from Insight owners.
Please state the following:
1. Lifetime MPG.
2. Mileage.
3. Current Average MPG.
4. Does everything work as well as it should (ie. few recalls, runs smoothly, etc.) if not please explain.
5. How well is your car's efficency maintained (ie. the tires always have lots of air, the oil is properly maintained, you use good gas, etc.).
6. Stock or Not; if not what Modifications.
7. Rate the efficiency of your average driving style (0-10; 0-You might as well be driving a Hummer; 10-You can double EPA MPG estimates in your sleep).
Thank You; these results will definately help me alot, and they will probably help others too.
1. Lifetime MPG.
2. Mileage.
