21 - 40 of 42 Posts
· Super Moderator
1.75 hrs billed for removal of old and install of new rear springs and shocks, at my local repair shop.
Though modest by shop standards, even that seems excessive. For an experienced mechanic it should be just minutes, but any shop is going to charge an hour.
Just lift, put a screw post under the axle, whiz out two lower shock bolts, drop axle and remove/replace. On a lift it can be done almost as fast as I can write about it ;)
On the ground, jackstands in back, floor jack under the axle, then same. Caution, the jack is just to hold the axle in place to remove the shock bolts. Will have to lower the axle an inch or so. DO Not jack an Insight by this method. A short length of 2x4 on top of jack will spread the jack load if you are concerned.
· Super Moderator
You just pop them out while you're doing the shocks. No spring compressor needed. Easy Peasy. The hardest part is jacking up the car.
2002 Monte Carlo Blue CVT
Preliminary impressions of Scott's uprated rear springs are favorable. Too me, they make the car feel more firmly planted on the road. Like I said, first impression after a 20 minute ride. I'll post more after I've lived with them for a while. Speed bumps will be the real test. But my deeply rutted, hilly gravel driveway is another and they were fantastic on that.
· Super Moderator
For me the best test is bridge approaches. It doesn't hit the bump stops anymore. I have them in any Insight that I'm going to spend any time driving. The cars without them just feel loosey goosey. The front springs make it even better.
2000 Insight, manual. 187k miles, 48.1mpg
Hm. I just picked up a set of rear shocks/dampers and was going to put them in this weekend. Do I have to remove the wheel, or can I be totally lazy and just pull the bolts with the car rear on stands+jack on the axle?
· Super Moderator
No need to remove the wheels.
· Super Moderator
You can be lazy, to install shocks in the rear, it is not necessary to remove the wheels. You will need a 14mm device, for the upper 2 bolts a swivel socket or universal joint makes life much easier. I also recommend about a 12” extension for either your ratchet or impact gun.
Scott
As a Senior senior citizen, I like the "ratchet or air impact gun" part. LOL
(New Meds)
Thanks! I have both (impact, extender, and joint) so I'll crawl under tomorrow and see how it looks.
Well, jacked the car rear up by the jack point, put a jackstand behind the rear wheel on the frame to bumper tube, and popped off one of the shocks. I can see why you need a universal joint to remove, and having air tools got the lower bolt out.
However the shocks I got from Autoparts store were.... wrong. Wrong length, wrong mount at the top, etc. The shocks are shot, I can squeeze them and they don't move back out at all. Oh well. What's the best place to get the GAZ dampers and does anyone have the part number?
I'll see if I can get Scott's kit by next weekend. The springs are probably similarly shot as well....
· Super Moderator
Good morning,
I normally have GAZ shocks, however I’m currently out of stock. It might be 2-4 weeks before they are here. There are 2 of us in the U.S. that carry them and we are both out, as we share inventory.
Scott
Ah ok. Well it's not going to get any worse and the old shocks (hah) are back in. Let me know the cost and such and I'll paypal you the money.
21 - 40 of 42 Posts
