Well at least I managed to order the correct spark plugs.
As far as crawling under the car to look at the rear mount, I guess I should consider getting a floor jack and jack stands. Also if this turns out to be the transmission and I might consider being crazy enough to try to swap the transmission for a rebuilt transmission myself I would need a floor jack and jack stands as well. I was looking at jack stands on Amazon. I am not so sure they look that safe to get under the car with using wrenches to do things like adjust the rear engine mount or remove/install a transmission. I also saw something that looked much safer than jack stands from a company called QuickJack. I was helping a friend work on a Cobra replica a while ago and he was using something under his car that might have been a QuickJack. I should ask him what he uses.Did the noise start only after you had the rear transmission mount changed? Hard to say what noise is the noise in your video, as there seems to be a lot of extra noise. But one of the noises, a kind of throbbing, thumping noise on acceleration, seemingly commensurate with engine speed, sounds to me like it could be engine/transmission mount related, like maybe when the rear mount was replaced it wasn't properly centered and 'balanced' with the other mounts, so maybe the engine/transmission are little off-center/kinked and rock and move in a weird way upon acceleration, putting weird stresses in weird places and making weird noise. Just a guess, hard to diagnose these things unless in-person.
You might consider crawling under the car and looking at the position of the rear mount - does it look centered, in a 'state of repose', at rest, or maybe the rubber stuff in the middle, like the 'arms' in the bushing, look stressed? Is the aluminum mount body seemingly straight/aligned properly with the holes/car body? Take a look at the front side mounts too and see if you can see any weird angles and potential stresses when the engine is just sitting there, hanging...
Yes, I have not called Scott yet. Scott gave me his number and a pricing information about a rebuilt transmission and estimated shipping costs across the country. I do suspect that the problem is the transmission, but I am not in a hurry to fix this. Others have suggested that I check on other items like the engine mounts, an exhaust donut gasket, etc. I don't think it hurts to check those items first before dealing with the transmission.Of course Scott will be able to diagnose it quickly. I bet you haven’t even called him yet.
I have a Quickjack and it works great. WAY more expensive than a good floor jack and four jack stands.
sam
Yeah, the Quickjack is WAY more expensive, but it does look MUCH safer. Plus the new TL models can get you 24 inches of lift. I was thinking maybe I can start doing more maintenance on my cars. I have 4 cars. The Insight is the oldest and who knows what might go wrong with it next. So I saw Home Depot had Quickjacks on sale and I had some credit card points that I could turn into a a Home Depot gift card and ... well I ordered a Quickjack 5000TL.Of course Scott will be able to diagnose it quickly. I bet you haven’t even called him yet.
sam
I have NEVER used auxiliary jack stands, or felt the need to. It’s really stable. I use the rubber blocks and put the front one under the reinforced pinch weld and the rear one just inside the body seam.Yeah, the Quickjack is WAY more expensive, but it does look MUCH safer. Plus the new TL models can get you 24 inches of lift. I was thinking maybe I can start doing more maintenance on my cars. I have 4 cars. The Insight is the oldest and who knows what might go wrong with it next. So I saw Home Depot had Quickjacks on sale and I had some credit card points that I could turn into a a Home Depot gift card and ... well I ordered a Quickjack 5000TL.
Originally Home Depot said it would arrive in less than a week. But the tracking info I just got now says 2 weeks.
While I am waiting, I read the Quickjack manual. There are a couple of places in the manual that say:
⚠ WARNING As an added safety precaution, you must always use auxiliary safety stands under the Vehicle while elevated on both QuickJack Frames.
While I don't recall seeing pictures of people using auxiliary jack stands on their website, I guess I need to buy jack stands anyway. Since it seems the only safe places to jack an Insight are the 3 places along the pinch weld where the Quickjack goes, I guess you need to put the auxiliary jack stands under the Quickjack?
So Sam, do you use auxiliary jack stands with your Quickjack? And if so where are you putting the stands? Under the Quickjack?
Well 2 of the 3 boxes for my Quickjack showed up on April 26th. I have called Home Depot too many times trying to get a new 3rd box sent to me. They keep giving me a different story, but assure me I will eventually get the 3rd box...Have you checked the inner CV axels? If the bearings inside them go bad they start to make noises as well. Cheap diagnoses can be achieved with stethoscope from harbor freight/ amazon/ Ebay. Again, you'll need jack and stands
You might try rockauto for the clutch, most people go with an exedy KHC11 I think it is, and some of the other brand names will actually be an exedy (I bought a 'Brute' clutch and it was an exedy). There was a thread not too long ago that mentioned clutches being discontinued, including the exedy, but there were 'some left' somewhere, you'll have to search for that thread...Are there aftermarket versions?
I suppose I could consider replacing the top left and right motor mounts too? The bottom mount was replaced already.
The manual mentions using a transmission jack to lower the transmission. Could I just use a floor jack to do that?
Somewhere else I saw someone suggesting an impact wrench should be used to get the spindle nuts off of the axles. Could I just use a breaker bar or a breaker bar with a pipe? I already have a breaker bar and pipe that I use to change the blades on my commercial mower. I guess I could consider getting an impact wrench if necessary.
Look what I found used on FB marketplace for $40. A low lift transmission jack. It was a bit of a drive though, over 40 miles from my house.You might try rockauto for the clutch, most people go with an exedy KHC11 I think it is, and some of the other brand names will actually be an exedy (I bought a 'Brute' clutch and it was an exedy). There was a thread not too long ago that mentioned clutches being discontinued, including the exedy, but there were 'some left' somewhere, you'll have to search for that thread...
I don't think I'd replace the front mounts unless I saw visible damage, certainly leakage (they're fluid-filled), but any cracks have to be carefully inspected, as superficial cracks develop quickly and easily but they're harmless. I replaced mounts that had "superficial cracks" but they turned out to be fine, the new ones made no difference.
I used a floor jack when I dropped my transmission to do the clutch, with a DIY block of wood shaped to fit the transmission. Didn't work very well. As I recall there's lifts you can buy that work from the top, like a crane, I resolved that making something that worked from the top, like a couple 2x4s and a ratchet strap or something like that, would be better than a floor jack with DIY block. I personally wouldn't buy a specialty tool, I'm too cheap.
I had no problems breaking 'spindle nuts' loose with breaker bar and socket, just do it before you lift the car.
Hmm, 32mm axle nuts. I just looked at my sockets. I have large SAE sockets, but my largest metric socket is 19mm. I will need to get some larger metric sockets then.Back in 2015, I removed the transmission on my 2006 Insight at home with my dad's help. We lowered it down with a floor jack. The manual transmission weighs about 60 pounds. It is isn't unreasonably hard to manage.
The axle nuts are 32mm. If the car is already on jack stands, you can have a helper apply the brakes while you loosen the axle nuts with a breaker bar.
Edit: If you would like to go with the high quality, tried and true, we have a few Exedy KHC11 clutch kits available.
