I can't tell from the pic, bad angle and lighting. But if it looks "straight" to you in person it's probably fine. Check the 'arms' in the center, the alignment of the aluminum housing versus the to-body attachment bolt holes (and any 'witness' marks from previous placement), and look at the rubber centers in the front mounts. There shouldn't be any obvious distortion in these things - kinking, twists, stuff should look centered, etc......It was suggested that I check to see if my mechanic attached the lower transmission mount correctly. I got a picture of it. It looks like it is on straight.
OK. I think I looked at the price of the Honda ones a while ago and they were much more expensive. If I can get better ones for $170, that sounds like I should order a set of them.I can't tell from the pic, bad angle and lighting. But if it looks "straight" to you in person it's probably fine. Check the 'arms' in the center, the alignment of the aluminum housing versus the to-body attachment bolt holes (and any 'witness' marks from previous placement), and look at the rubber centers in the front mounts. There shouldn't be any obvious distortion in these things - kinking, twists, stuff should look centered, etc...
I briefly skimmed the rest of this thread. People have mentioned possibly bad CV joint/s. Looking at your pics of the axles, they look pretty rusty and crusty. You asked whether there were something else you should be doing/buying during all this, and I think it might be worth buying new axles. They're not very expensive, about $170 for both (rockauto), and the right aftermarket replacements - "TrakMotives," at least - are beefier, stiffer, and make a pretty big differences in the rigidity between wheels and transmission. Here's a link to where people have talked about that: Got a manual trans G-1? get rid of the wimpy axles...
I just ordered the CV axles from RockAuto with cheapest shipping for under $125.OK. I think I looked at the price of the Honda ones a while ago and they were much more expensive. If I can get better ones for $170, that sounds like I should order a set of them.
Mood. I have seen other cars axles fail internally with no visible signs from the outside(as I said in another post, I replaced a S80 V8 axle recently) but never an insight. 50k, 500k, doesn't matter, it just doesn't seem to happen. Honda reliability really gets me sometimes.Insight axle CV joints basically don't fail or wear out on their own.
In the land of no rust, the only thing I've seen kill Insight axles is when the inner joint gets over extended and subsequently isn't put back together properly.
It seems that changing the cv axles and changing the clutch are just extra things to do, but the noise seems to be saying transmission rebuild. So I should just contact you about doing that.Insight axle CV joints basically don't fail or wear out on their own.
So looking at the closeups of the tires, do you still see something wrong?The passenger (starboard) side looks to have negative camber issues to wear the tire like that. Something up w/ the strut or control arms?
No & tks, it must have been the initial angle of the picSo looking at the closeups of the tires, do you still see something wrong?
