17mm hex heads? This is what the bolt heads look like for my car. I have a 2005. The 2 bolts with the washers and countersunk holes were the bottom most bolts.There are six bolts that hold the transmission to the engine. The upper four bolts have 17mm hex heads and the two bottom ones have 14mm heads.
The trickiest one is high up on the back side of the engine under the exhaust manifold section of the head.
FadedBlue, you have my phone number. Please feel free to call me if you have any questions while working on your Insight.
Well if I order the 2 top motor mounts, the driver side looks easy enough, but the passenger side mount has something in front of it (maybe related to ABS brakes as it has some hard lines coming out of it). Can I just unbolt the thing in front of the passenger side mount and lift it out of the way so I can get the bolt out of the motor mount?Congrats on getting it out.
Yea that motor mount is getting tired.
