Interesting find on the manual bit.
When I work on cars with steps like such, I write a note on the window (usually on a piece of blue painter's tape) reminding myself I disconnected this, etc. then stick it on the door window, quarter glass, or windshield - essentially anywhere that will be very noticeable. Glad to see the IMA light is now off!
I tried to be organized. I was putting small parts in envelopes and marking the envelopes with page and step number from the removal steps. That was helpful when putting things back together.
This morning I was thinking that there must be some thing I missed, like forgetting to plug in a connector. But it seemed that I plugged them all back in. Then I was thinking I should go back over the removal steps in the manual to see what I could have missed on the re-install steps. And without even going back over the manual it occrurred to me that probably the first thing I did was turn off the IMA high voltage switch. And then I thought, it is unlikely that I switched that back on as I had a bunch of tools and stuff in the cargo area.
Well it is a relief that I just had to throw the switch because I wasn't sure what to do next.
Hmm, I should have checked if the Air Conditioning was working this morning, but when I took the car out this morning it was not hot enough outside to tell. I will check that later, but there is always the chance that I broke the Air Conditioner when replacing the passenger side motor mount with stuff I had to move out of the way. I am kind of hoping that Air Conditioner does not work when IMA switch is off and will work again with the IMA switch on (but that is probably just wishful thinking).
