Following my posts on the "Insight GPS Nav / TV System Pics" topic, I finally upgraded my audio speakers last weekend for a much improved sound. I thought it might be useful to share my experience - I hope the links work.
For the record, the OEM speakers are 4 ohm, 15 watt, 16cm in diameter (about 6 and a quarter inches) and have a maximum mounting depth of no more than 5 cm (about 2 inches). The OEM speakers use triangular screwholes, therefore to do a easy straight swop, you need to find a speaker that meets the size requirements above and has 'universal' screwholes. Beware that a more common speaker size is 17cm or 6 and a half inches; 16cm takes a bit more shopping around (at least in the UK). No doubt the more handy of you out there will be able to work around this size problem.
One of the best straight swop speaker I could find was the Pioneer TSG-1630; however I went for more power and a deeper basket and chose the Pioneer TS-E1675 (at least 50W each). This photo shows both the old and the new speakers above the rear right speaker fitting.
http://uk.photos.yahoo.com/bc/christian ... ft.jpg&.sr
You will note that there is a black plastic OEM back to the rear speaker fitting and will have seen the very close proximity of pipework. Anyone intending to install their own rear speakers in this area should keep high and to the side of of the car to avoid this pipework.
The same can be said of the rear left hand side (American drivers side) where there appears to be orange fittings quite close as well. Please see second photo.
http://uk.photos.yahoo.com/bc/christian ... pg&.src=ph
The third picture shows the start of cutting away part of the fitting in the front right door; this will be necessary for nearly all speakers except those specially designed with a 'shallow basket'. There is at least another inch or 2cm behind the OEM fitting before you hit the side impact bar(?) or window storage.
Depending on the protusion of your new speakers, you may also find it necessary to 'shave' some of the inside of the speaker grill. The speaker wiring table which is on InsightCentral under Knowledge base, I found very useful; I hope others find my post useful too.
