1 - 14 of 14 Posts
After some inspiration from blue civic hybrid and KLR3CYL I decided to mock up and make my own aero panel. It's .093" polycarbonate from Home Depot. I added a PVC oil drain to match up with my Fumoto oil drain valve and a thumblatch door for oil filter access (as well as coolant petcock). I decided on a couple pieces of aluminum angle stock to counter any pressure from the front bumper puts on the 2 rear bolts. Just got it on today and only drove < 10 miles. So far no rattles (up to 75mph) so far. I might be crazy but I think I notice a slight increase in road noise under 10 mph. I will be back later this week to report on any mpg increase (over no aero panels that is).
Very nice workmanship!
I would also like an access hatch for the filter, but Scott did such a nice job on the aluminium panels, I don't have the nerves to mess with it. :) At the minimum, I will have to ask for his forgiveness before I cut into it. :)
I do wonder how the plaxi will hold up under the car. Will it get scratched from sand etc flying under the car? I think it will make Oil changes easier, because you won't have to grab for stuff blindly.
OT, but I was also planning on making a plexi see-through cover for the battery. Yes, just for cool factor, and to be able to educate the uninformed. They are not cheap though.
Careful with that stuff it spiders easily.
Southern California
I believe polycarbonate has a fairly low melting temperature, so it might start to droop in proximity to the exhaust pipe. We'll have to see what happens.
Read Only
Would it be possible to mount this aluminum angle on the top side of the polycarbonate (i.e., out of the airstream)?
Discussion Starter · #8 ·
Art, I would have preferred placing the beams up inside the fairing, but the right/ passenger side it would be too close to the oil pan for my liking.
Very nice work, I like the access door , and the fact that you can check for leaks,etc. I believe you could sell a few of these.
I always change the filter from the top. I use a filter wrench that grips the bottom of the filter an fits a ratchet (from Walmart). Reach behind the radiator. Use a large rag under the filter to catch spillage.
Maybe my hands are smaller...
Discussion Starter · #11 ·
Freezin4 "I do wonder how the plaxi will hold up under the car. Will it get scratched from sand etc flying under the car? I think it will make Oil changes easier, because you won't have to grab for stuff blindly."
We'll have to see how well this stuff holds up cosmetically speaking. I started out wanting to use .062" aluminum, however where I live we only really have a Home Depot and they do not stock that. I do like the polycarbonate, IMO it looks slick.
Maximumfuelage "Careful with that stuff it spiders easily."
I'm going to keep a close eye on all the mounting points for a while. I really think the angle aluminum bars should keep the movement to a minimum though. Fiber washers are a good idea on the mounting bolts as well.
Mario "I believe polycarbonate has a fairly low melting temperature, so it might start to droop in proximity to the exhaust pipe. We'll have to see what happens. "
Great point! I fixed a couple of temperature sensors at the point closest to the exhaust (about 4" away) and directly under the oil pan (about 1" away) and will monitor them for a while. Melting point is 155 degrees C, so I hope it doesn't get any where near that temp.
TX-WA "I always change the filter from the top. I use a filter wrench that grips the bottom of the filter an fits a ratchet (from Walmart). Reach behind the radiator. Use a large rag under the filter to catch spillage."
Thats a great idea, I've never tried that yet. When I thought this out I wanted to keep true to the Fumoto valve mentality and keep it to where the only tools I need for oil changes are a catch can , and a funnel. We'll see if I can still reach up and spin off the filter with my hand through the 6.5" X 15" door.
Looks great!
That looks great for a panel! And as others have stated, I would just watch out for spider cracks, heat stress, and if you actually do hit something in the road, lets hope that it doesn't shatter.
I had my DIY panel for about 3 years with about 120k in driving on it and I had some deep gouges in the aluminum from random objects on the freeway that I couldn't dodge, plus my car was lowered too!
I really like the fact that you made those access ports for the oil change and filter access.
Discussion Starter · #13 ·
Just an mpg update...After putting 600 miles on it my average has gone from 62 -64 mpg to 70 even.... everything seems to be holding up fine, no vibrations, melting or discoloration. The highest recorded temp I got closest to the oil pan was 150°f.
Discussion Starter · #14 ·
Update - I do have 2 screws on one of the support beams with spider cracks (> 1/4"). Don't think it'll be detrimental structurally speaking.
I am getting around 5 percent better fuel economy, and I believe that's a conservative estimate. The real benefit I'm seeing is when driving into a moderate or heavier headwind. Many days I drive home from work ( uphill and 15-35 mph wind) and have noticed a much more consistent mpg vs. no aero panel installed.
1 - 14 of 14 Posts
