21 - 23 of 23 Posts
Discussion Starter #21 (Edited)
The gloves are not the problem, Peter!
I will dig into the "battery compartment opening videos".
Maybe you tell me exactely where and what to measure...
If you got some pictures i would like to consult them to know exactely what waits for me unter the trunk.
It´s 3 years since we where at your place and unfortunately i took no pictures of the battery bay etc.
Loads of pictures/videos on here or google about what to expect.
You need to be measuring voltage at the grid charger connection points on the battery switchboard.
Discussion Starter #23 (Edited)
I searched for someone that uses your system (like me) and posted a video about opening the trunk area but i was not very successfull.
"Can you measure the battery voltage with a meter when it is charging?
Can you measure the current it is delivering?"
Voltage = parallel measuring (at the plus and the minus pole)
Current = serial measuring (i have to dissasamble a pole of the charger and fit in the meter)
EDIT: Is it necessary to disconnect the 12V battery while discharging or charging. My 12V Battery was always connected.
21 - 23 of 23 Posts
