How many miles does your car have?(can't help you with problem just noticed your sig line).
That's why I was using it as an indicator of an overly rich engine. As the service manual explains, this code is common in a misfire/rich situation. It instructs that all other codes be troubleshot before P0420...Insightful Trekker said:A P0420 is a CAT code. And will set as a reflection of:
1) An "overloaded" _or_ marginal CAT. Anything that causes poor combustion efficiency.
Ideally. Yet my plugs showed significant wear at 100,000KM (~60K miles). Mine were WELL out of spec.By Dan's previous posts he's got 70+K on his second set of plugs right now. Should be OK for a full 105K interval.
EGR cleaning is very easy. But I often find it trumpeted as a magic bullet to cure all Insight problems. So it might help in your case, but I doubt that it will.Is there a procedure for this cleaning? I, unfortunately do not have access to all the test equipment, and my dealer who has done well for me so far cannot find any codes signifying anything. I'll try the EGR cleaning if someone can give me a procedure and maybe a picture or 2, but after that, I have hold out for a new Insight or IMAS.
Newer type clogs tends to be slight and at the end of the line where the passage tends to be the coldest and the soot "freezes". This then causes an EGR flow imbalance in that some of the cylinders get a disproportionate amount of exhaust gas during EGR on time and therefore a lesser fuel air charge resulting in jerking, bucking, hesitation, etc. (a power imbalance) The Insight also has an "unusual" amount of EGR "on" time.Calpod said:I believe is the valve sticking rather than being clogged, I have removed clogged EGR valves before, and you cannot see the passages at all.
Check the latter parts of this thread for the proceedure:dfiore said:It has problems, just nothing you can put a finger on without spending a ton of money. I'll be cleaning out the EGR valve, but unless something gets worse, I don't think I'll be able to figure it out. The EGR solution has been suggested the most and that is the route I am going to pursue.
Thank you very much!
