Wasn't someone offering one just last week in North Texas? Pickup required before it was to be tossed...
2000 Honda Insight
2003-2005 Civic Hybrid transmission will work too, with a little effort. Not exactly the same gearing, but some say it's an improvement. I'm eventually going to try it.
2002 Monte Carlo Blue CVT
What makes you think yours needs a trans, as opposed to say, an input shaft bearing? If you are doing the input shaft bearing, you might as well modify the second gear synchro tabs and, depending on wear, replace the clutch.
