1 - 2 of 2 Posts
To make things even easier for our customers, we offer toolkits for rent. These are intended for those who don't have an array of tools and renting a set is cheaper than going out and buying the tools. The kits include:
voltmeter
10 mm socket
12 mm socket
1/2" socket (for the crate)
ratchet
extension (for the battery bolts)
Torx T30 bit
longnose pliers (for the trim clips and the wiring harness clips)
The kit rentals are $20 for the duration of your repair. There is a $50 refundable deposit required on all toolkit rentals.
We assume that you have a phillips-head screwdriver for the crate, because you need one to open it and get the toolkit out. :D
1 - 2 of 2 Posts
