1 - 20 of 35 Posts
I remember when Scotty first posted this. It is impressive and it looks better than the Fumoto. But, I already have the Fumoto, I have a belly panel so it will not get hit by rocks and a plastic line on the nipple and I am in business. Were I starting now I would get this one. It looks great. Thanks for posting this.
Scotty is entertaining. I noticed that the faster he talks, the more his arms and hands flap. I expect him to "take off" one of these days.
My Fumoto valve has worked right for over 400K miles, I think I'll stay with that.
+1. I prefer the Fumoto. Why have an extra part that you have to track down? I've never heard of the valve being accidently opened on a Fumoto. Has anybody? The threads on the new one also look shorter. No, thanks.
Since when did removing a regular oil drain nut become such a hassle lmao
It's not a hassle if you do it yourself, and if you're careful with the torque. Many $350 oil pans have been ruined by monkeys at oil change places. I really like the idea that I will never have to touch those expensive threads again. Also, it's a lot less messy!
Solid point. I have heard these oil pans strip out rather easy
Did Rainsux jinx me or did I jinx myself lmao! (ps: I stripped it out myself)
I think I could get away with installing a fumoto oil valve with maybe red loctite using very little torque. just leaving it snug i guess... thoughts? Where's the best place to get the valve?
Thanks guys...
How come it looks like most people recommend the Fumoto F106N? That's the extended nipple version.
Wouldnt the regular F106 be better since it doesn't have a nipple, hence nothing to snag on and rip the valve off?
A nipple isn't going to snag on any thing, unless you are wearing dentures. Seriously, the drain is in a horizontal plane, so nothing is hanging down to get ruptured or snag on anything. The extended nipple is in case you want to add a drain hose. .
oh haha I see what you mean. I just took another look at it. Thanks. Do you think I'll have enough threads left to use the fumoto valve? I sure hope the red loctite works
that Scotty guy is really entertaining
I too am rather in love with fumoto, and will stick with it. if fumoto's never existed, I would probably give this one a try
DaBossk:
You will be removing the spacer plate on the pan when installing the Fumoto, so there may be a few threads still usable as it will screw in further than the std. drain plug..
DaBossk:
Dang it. I had no idea I had to do that. My fumoto has already shipped. Do you think the oil pan is in the right spot and is the right design of oil pan to get a helicoil or something similar to save the threads?
I'm running a rubber oil plug right now, the plan is to just take it to a mechanic for my next oil change and have him heli coil it, then install the fumoto...
Why does that spacer plate have to be removed anyways?
edit... I dont want to tap to a size bigger becuase then I'd have to return and buy another fumoto
Removing the spacer gives you a couple of more threads. It's only one bolt. Just do it and do a trial fit with the Fumoto. If it catches at all (it will) then do your threadblocker thing. Done.
If ALL your threads are gone, have the mechanic install an "insert", not a helicoil.
The proper insert to be used is a,”Timesert” brand. IIRC it is a 14x1.5. We use them all the time and restore the threads on Insight oil pans, we have the kit in stock at the shop. When I install the Fumoto valve I use a little Honda bond at the base of the threads.
Also, do take off the little spacer as others have mentioned.
HTH,
Scott
1 - 20 of 35 Posts
