Ac heater works fine but if I turn it on this clicking noises comes from the engine bay. My ac blows cold and my heat blow hot. It’s just this noise is super loud.
Debri in the squirell cage?
fan noise
So it sounds familiar to a noise I had. I juiced up the ac system on my new 2000 mt with air and the fan on the back side of the radiator to the left side started to turn on and actually hit the frame as it spun , it was extremely loud. I fixed it by trying to flex the frame until the noise disappeared. I ended up pushing a piece of rubber hose in between the radiator and the fan frame. Probably the real fix is to pull it out so you can see where it hits as it spins.
TaoHonda:
I assume you have G2 Insight. If so, please put that info in the Signature part of your Profile.
Thank You
willie
