21 - 25 of 25 Posts
2001 CVT Insight “Cherry Bomb” 330K+
Discussion Starter · #21 · (Edited)
1 leak down, 2 to go! 🤦🏻‍♀️
Cleaned up the cap and put a worm clamp on- problem solved. However, there was still some major leakage. Found that the right of the two hoses on the back of the outlet was leaking. I didn’t put the clamp back in its original place, but even after adjusting it, it’s a slow seep and I’ll probably just need to replace the whole hose as it seems kinda stretched out. Would anyone by chance know the diameter and length of that?
Automotive tire Hood Motor vehicle Vehicle Rim
The one that’s gonna be a major PITA tho (not the bread, as I believe it was Joule who said 😂) is the right of the two pipes on the front. I replaced the rubber o-rings on both of those per Bulldogs guidance, as well as cleaning up a lot of the corrosion that was there. I assume I didn’t clean it up enough, or is it possible that the rubber ring isn’t in far enough/ seated correctly?
Automotive tire Motor vehicle Automotive design Rim Automotive exterior
Man, this is frustrating.
Yea looks like it didn't seat correctly? I put some white lithium grease on those o-rings before pushing them in on my rebuild. Mine gave a 'pop' feel when they slid in
  • Like
Reactions: CherryBomb
Discussion Starter · #23 ·
2 leaks down, 1 major leak to go.
Bull Dog rang me up and gave me some pointers. He suggested I adjust that hose, pulling it back a little since it looked like it was on too far- that did the trick.
Then for the pipe, he suggested I try and nudge it back in, also checking that the plate for the bolt wasn’t twisted or bent. It was. So, I was gently trying to tap into place with a screwdriver padded with paper towel but wasn’t really doing much. Then. Then. A certain someone came home from work and gave it a go (no padding, unbeknownst to me), and basically destroyed some things. Haha, not really but man was I mad 🙂 The plate not only got damaged, but also bent inward towards the seal and I believe ripped/ punctured it. Coolant started running out a ton (it was just a slow seep before this), and I think all that made the pipe pop out more actually.
Gas Rim Auto part Metal Nickel
Not sure the photo really shows well enough, but that plate is now actually “ripped” or “torn” off the pipe a little where it’s now pushing on the seal. Gonna need a new seal I’m assuming. Already drained the coolant and will begin the long, tedious process of removing everything again. @Bull Dog I’ll give ya a ring tomorrow 🥲
2002 Monte Carlo Blue CVT
Stuff happens. Deep breath, good night’s sleep and give it another go. You are probably going to have to replace that hard pipe. Scott K may be able to supply good used unit.
21 - 25 of 25 Posts
