My '00 Insight with 65k miles is recalling very frequently, so I asked my Honda dealer to check it out at last oil change. They said there were no IMA errors, and handed me the following information:
"Batter Level Gauge Reading Suddenly Drops
On '00-'02 Insights, the battery level gauge doesn't read the battery level directly. Instead, it calculates the level by continuously measurng the current flow, voltage, and temperature.
Since the IMA charge level isn't read directly, small sensing errors can, over time, cause the gauge to read higher than the actual battery charge level. The IMA system then does a self-correction, and the battery level gauge reading suddenly drops. When this happens, IMA assist and the Auto Idle stop function are disabled until the IMA battery is recharged enough by normal driving. This should only take a few minutes.
This correction of the battery level gauge is normal and doesn't mean there's a problem. If the IMA battery develops a problem or it becomes deteriorated, the IMA system indicator comes on.
You'll notice this correction taking place in this common scenario: After having parked the vehicle with the IMA battery at least 50 percent charged, you start and drive the vehicle a short distance (a block or so). The battery level gauge now indicates zero charge, and the IMA charge/assist gauge indicates the IMA battery is charging. This is a normal characteristc caused by the IMA battery self-correction process."
The recals are very annoying as they kill the milleage and the power, and happen at least once a week, sometimes stranding me mometarily at a traffic light when the autostart stops working. I just hope if the battery ends up dying, it's before the warrantee runs out. (then again I may not have the battery warrantee as I bought my insight second hand?) There were no recals when I first bought my Insight. I think I went too crazy with the assist and permanently weakend my battery? I never seem to get full assist now for more than a second, no matter the charge level.
John
John
