281 - 288 of 288 Posts
Discussion Starter #281
OBDIIC&C Availability Update 12/01/2020
Because a lot of people have been enquiring about this recently I
have reordered another 100 pcb's for self builders or for me to build up complete units.
It's a good old workhorse and still has life left in it i'm sure.
As you know it can me modded in various ways and might also
find new life if we can develop an Android App.
I have sourced some of the discontinued 5 ways switches.
I have stacks of OBDII plugs.
I also have some 3d printed cases on order.
So each bare pcb will come with a switch, switch cap and obdii plug if you are self building.
E-mail me for details.
Very useful device, with lots of life/utility remaining. I have two of them, one configured for the early Insights and the other for the later model years and use one of them every time I drive one of my Insights. I rely on the lean-burn indicator LED daily, while the DTC code read/reset and data logging are useful when needed.
While slightly off-topic, some life-extension ideas for the OBDIIC&C might include integration (of the features, perhaps not the device itself?) with Pegasus, and integration with the BCM replacer for those folks who are not running MIMA/IMAC&C with their Li setups.
I'm having trouble locating info on how to configure ODBIIC&C to show more accurate Bam readings post LTO/2019 Current Hack installation.
Would you mind sharing what menu this setting is located under, and what the setting needs to be changed to?
Discussion Starter #284
It's in the main menu under 'Amps Hack Val'
Decimal AmpHackValue 100=0% 125=20% 143=30% 147=32% 154=35% 166=40% 200=50%
If the menu entry is in hex then set it to the hex equivalent of the above. . i.e. 166D = $A6
Discussion Starter #286
Looks like a bug.
Try earlier or later firmware depending on what you are already running.
What happens if you press U/D?
