@retepsnikrep
Going by this diagram, with the pins as written in the bottom right of the photo, at the OBDIIC&C gauge I use the following pinout:
1 - Orange/White - Optional - this is RB1 on the Pic
2 - Orange - DLC Pin 16 +12V
3 - Green/White - DLC Pin 14 H-Line
4 - Blue - CAN High
5 - Blue/White - CAN Low
6 - Green - DLC Pin 7 K-Line
7 - Brown/White - DLC Pin 9 - SCS on the Pic
8 - Brown - DLC Pin 5 Ground
So, at the OBDII connector, Orange/White, Blue, and Blue/White don't get wired to anything..
This ensures compatibility with my newer CANBUS integration wire harnesses. I think you've got the older version (green PCB) which was a prototype and the PCB should say V0.00 on it.
Earlier this year I developed a new, complete kit, the point of which was to greatly simplify the wiring required to have the OBDIIC&C hook up to the LTO BMS modules. Around the same time is when Adria's OBDIIC&C went bad, so I decided to try to solve a bunch of issues all at once by attempting to improve the OBDIIC&C PCB and attempting to improve last year's version of the LTO BMS wiring. Half-way through this effort Greentec sold out of the LTO batteries, so further progress on this is now pointless, but I had a good time trying to get better at reading wiring diagrams and designing PCBs.
There are three PCB components for my system:
IPU CAN Integration Module V1.0.0 PCB <-- This is the updated version of the pcb you've got at the end of the LTO BMS pigtail thing I mailed you
Under-Console CAN Integration Module V1.1.0 or higher PCB
OBDIIC&C 1.1.0 or higher PCB
(Click for full size)
When I started this and mailed you the IPU LTO BMS connector you've got I didn't know about semantic versioning, but now everything uses it. I have the new PCBs for those two modules printed blue, to indicate incompatibility with the green ones. There are a few more improvements that can be made, mainly with the module that goes under the console, but because the LTO supply is gone it'll probably never get done.
I also added pins for IMAC&C switch wiring to the 1.1.1 version of the OBDIIC&C PCB, but those would need their own separate dedicated wire. I've never seen an IMAC&C in person so I'm not familiar with their wiring requirements.
I know this is all probably really confusing, but when this system is wired up properly, all you need is 1 single connection to the car's factory wiring, which was the primary goal. Secondarily, the OBDIIC&C can now easily be removed from the vehicle by simply unplugging it at its on-board RJ45 jack. Adria now has this new system in her car. Jeff has an older 1.00 OBDIIC&C that I retrofitted with an RJ45 jack to this specification, so should down the road he ever go LTO (probably unlikely) his gauge will be compatible. In a couple weeks Lily is leaving the country for an extended period, so I'll be taking care of her Insight, during which time I'll also upgrade her LTO CAN wiring to this new standard.
