1 - 20 of 225 Posts
This thread is to document/discuss the modification of the OBDIIC&C device to enable it to work on the Gen1 Civic hybrid.
A first test with a standard Insight Gauge just leaves the gauge hanging at the "Waiting for OBDII port" message.
So a look at the Car OBDII Connector diagrams shows they have the same pinout. See pic's.
A subtle difference is that the MCM in the Civic is not connected to what I would call the HLine on the Insight which is. The MCM in the civic has proper two way serial comms line with the ECM unlike the Insight so comms is obviously via the ECM in this case.
It looks highly likely that all comms with MCM is done on the standard OBDII KLine.
However comms with the ABS,IMOB,SRS,EPS is done on the HLine as with the Insight. So it still requires the 5V HLine bus on pin 14 to talk to those units.
As the KLine must be OBDII compliant for a Scangauge to work then the basic ECM PGMFI data should be easy to obtain.
The OBDIIC&C software is looking for 5v on the Hline at present in order to start up, the circuit diagram indicates that it should be at 5v.
Need to capture some data to see what is happening. :roll:
How did miss this thread? What pin is the H line? Let me k ow what I need to do and I can try it on my HCH1.
H Line is pin 14 on the HCH1 pinout below. It's the same for the Insight though so is already wired up. Just plug it in and report back what happens please.
Plugged it I just now, only get message "waiting for OBD port" when ignition is turned off reads "OBDIIC&C Data Saved"
Moved joystick up, left or right, no response
Moved joystick down, get the IMA menu, shows battery voltage at 0 volts, none of the functions work, but all the IMA menus are present.
Thanks for that. I can't do anything now though until i get access to an HCH1 over here hopefully later this month. Probably nothing too complicated with luck ;)
So when I'm building, just make everything as for the I1... got it.
I'm aware, but I'm building in a week and bought knowing I'd be a guinea pig (well one for my HCH and one for my dad's Insight), so...
I also bought 2, but I'll wait a little longer in case there are changes to the Civic.... I have 2 Insights and 1 HCH.
Moderator
The Scangauge/Ultragauge et. al. will work with all protocols - PWM, VPW, ISO, CANbus.
Discussion Starter #13 (Edited)
I have now firmed up arrangements to go and gather some data from an HCH1 next wednesday/thursday. 1st priority will be data for OBDIIC&C, secondary will be listening to that comms link between ECM/MCM for my Civic IMAC&C project ;)
Between now and then I have several 12hr works shifts to do :( So not much else project wise going to get done.
Discussion Starter #14
Gathered a huge amount of HCH1 data today to sift through. Going to get some more tomorrow. Now sitting in a bar miles from home studying it. Lots of work to do.
In the HCH1 it appears the IMA data is on the Kline rather than the Hline as with the Insight G1. Abs, eps, srs etc on Hline as per G1
The data structure is different so some software mods reqd for OBDIIC&C to work.
I'll keep you posted.
Moderator
Interesting that it's so different, wouldn't have figured that.
Great to see some action on this front! I'm getting jealous of these other people with all that sweet, sweet data.
Gotta figure out how to data log from the serial port in Linux.
EDIT: Seems easy enough:
ttylog -b 9600 -d /dev/ttyS0 > file.txt
Discussion Starter #17
Data gathered
Finished ther initial Civic HCH1 data gathering, it will be several weeks before we see a test version of OBDIIC&C for the Civic but it will be possible from first glance :)
Logged some relevant IMAC&C data as well, a combined device for the HCH1 might be possible later.
Well, if you need a firmware beta (or alpha!) tester...
1 - 20 of 225 Posts
