New OBDIIC&C PIC18F2680 LTO CAN code 13/10/2020.
It's set for my UK 72 cell LTO car.
IMAC&C P&P is
OFF.
Current hack is set +40%
If in the US you normally go into the menu on first run and change... (See note below!)
1) The country/year defaults. (Gauge will immediately reboot)
2) LTO ID's
3) IMAC&C P&P config
if it's fitted.
4) Temp Display C/F
5) Anything else you want...
It has a couple of useful improvements.
1) CAN bus error filtering and bad packet rejection.
This should greatly reduce/eliminate spurious errors and alarms caused by bad CAN frames/packets.
2) Menu delay implemented to slow it down when scrolling!
Please post feedback. Thanks
Rename attached file to
hex as usual.
Note..
No changes have been made to the Eeprom data in this version.
It should be possible to install this updated firmware over the previous version (post 267)
without having to set the gauge up again from scratch afterwards.
To try this
untick the
'EEPROM data enabled' option in the pickit programmer software
before programming.
If you don't have the previous firmware loaded
or it doesn't work as expected you will have to tick the
'EEPROM data enabled' option, program again and set the gauge up as normally.
