Hey
@retepsnikrep I was riding with
@Adria in her LTO Insight last night. She had a SRS light that she couldn't reset, so I went to show her the OBDIIC&C menu item where one can read the SRS code.
When I selected Read SRS DTC or whatever that option is called, it said no codes found or whatever the standard message is. Pressing left and right didn't get it to show anything. But, when I pressed the button in, to go back to the menu, something happened where the OBDIIC&C had most (possibly all?) of its parameters reset! The screen went really dim, the screen parameters got messed up, the splash screen stopped loading, and so forth. LTO block IDs were all zeroed, and many menu parameters were zeroed.
I tried multiple times to enter the menu by pressing the centre button but it usually reset itself immediately. But eventually I was able to enter it and use the "reload config" to restore the gauge to normal operation. However, attempting to check the SRS codes once again messed up the OBDIIC&C parameters and the gauge went dark and such.
Is there anything that you can think of that might lead to this issue? Do you think there could be a hardware problem, or is it potentially a software problem?
