This version superceded by hyperlink #15
This thread is to provide a list of typical values of the ECM(US) variables on the OBDII C&C gauge. Hopefully the list will prove valuable for trouble shooting purposes. I will edit this thread from time to time in the hopes of keeping it concise and on topic topic. (If I delete your post, please pick a relevant thread or start a new thread.) Feel free to populate the list with you own measurements. Only list typical values for smooth running cars, warmed up, with no CEL or IMA lights lit. I have left out the variables which have little relevance to troubleshooting.
Typical OBDII C&C ECM(US) Values:
Brake Switch(Brf)=
Starter Switch(Stf)=
Vtec Oil Switch(Vtf)=
Vtec Solenoid Status(Vts)= 0 Vtec off, 1 Vtec on. (kinda obvious and there are other binary values I think
Air Cond Switch(Acs)=
Imoblizer Run/Ban(Imo)=
MIL Light On Off(Mil)=
Clutch Switch(Clf)=
Neutral Switch(Nef)=
SCS Open or Shorted(Scs)=
Main Fuel Pump Relay(Fpf)=
DCDC Control Status(Dcf)=
IMA Standby((Ims)=
Starter Control(Stc)=
Idle Stop Control(Ids)=
Radiator Fan Status(Rfs)=
Engine Coolant Temp(Ect)=187-212F
Engine Air Intake Temp(Iat)=Highly variable depending on climate and season
MAP Pressure Kpa(Map)=stopped 101>102, idle 31>37, hard accel. .99>1.01, cruise 55>80, LB 48-85, trailing 24>25
BAR Pressure Kpa(Bar)=
Throttle Position %(Tps)=
1st O2 Sensor Cur ma(Ofc)=stopped 10.4, idle 0, accel 1.6, cruise 0, LB -1.6 > -2.0, deaccel. -5.6
12V Battery Voltage(12v)=
Soc Voltage 0-5V(Sov)=
Electronic Load Amps(Eld)=
EGR Valve Feedback(Egr)=Idle 1.02, Accel 1.02, cruise 1.02 > 2.00, LB 1.02, deaccel 1.02
Short Term Fuel Trim(Stf)=Idle .09, Accel, .09>1.00, Cruise .09>1.00, LB .09>1.00, trailing .09, deaccel .09
Long Term Fuel Trim(Ltf)=(Current test car displays XXX, Current ECM version provides no readout)
Fuel Injector ms(Fin)=CVT(non LB)< .6 = 1 L/100 km, .35-.45 = 1/2 L/100km:MT stopped .00, idle .78>.84, hard accel 3.8>4.0, cruise 2>4.5, LB 1.00>1.15, trailing 0.0
Spark Advance Degree(Spk)=stopped .00, idle 12, hard accel. 0>19.5,cruise 20>30, LB 31.0, trailing 14>16
Knock Retard Degrees(Knk)=
Idle Air Control Vlv(Iac)=
Air Fuel Ratio(Afr)= normal cruise 13.7 >14.3, MT LB 22.4 > 21.8
Evap Purge Control(Evp)=
Evap Bypass Solenoid(Evs)=
Fuel Tank Pressure(Ftp)=
MIL Lamp Status 2(Mis)=
Fuel System Status(Fue)=
Engine Load(Lod)= 0-100% non-LB,up to approx. 92% and unstable in LB
2nd O2 Sensor Vlts(O2v)=stopped 0, idle .08, accel. .08, cruise .07, LB 0, deaccel. 0
2nd O2 Sensor Heater(o2h)=
IMA Motor Torque Nm(Itq)=
Brake Boost Pressure(Bbp)=
Engine Torque(Etq)=
IMA Request =/-9.9kw(Ikw)=
Reversing Light(Rev)=
Brake Switch(Brf)=
Clutch Switch(Clf)=
IMA Standby((Ims)=
Engine Torque(Etq)=
