I will be importing my 2000 Insight into Sweden this summer. One of Sweden's inspection checks before allowing an imported car to be registered is tire condition. With only 22,000 miles on my Insight, its tire's tread depth meets Sweden's requirements. But because these tires are 9 years old, they're beginning to show signs of rot cracking which may result in my Insight failing the inspection.
I have searched Bridgestone's European Website for the Potenza RE92 165/65R14 OEM Insight tires, but no Potenza RE92 appears to be sold in Europe. Bridgestone's recommended Insight replacement tire is a B250, but no 165/65R14 is available. The closest size is 175/65R14. Unlike the OEM tire, the B250 does not appear to be a low-rolling-resistance, light-weight tire. It just seems to be a run-of-the-mill small car tire.
For those of you living in Europe, what tires do you put on your Insights? Is there a low-rolling-resistance, light-weight, 165/65R14 tire available? If not, I might be able to ship a new set of Potenza RE92's with my car, but I'm running tight on space in the shipping container, so I'd rather buy tires in Sweden if I have to.
