1 - 3 of 3 Posts
This taken from a thread today on the PriusChat forum:
Summary of problems reported on Prius 2010
List of problems reported on the Prius 2010
Problem: Red arrow in energy monitor hard to see in daylight
Description: Fix for difficulty seeing red arrows on Energy Monitor Screen in daylight (2010 Prius II)?
Solution: Pending
Problem: Car computer overestimates MPG
Description: 2010 calculated vs. computer MPG - Please post your results
Solution: Pending (Toyota has been made aware of the problem)
Problem: Air Conditioning display is cloudy/blurry
Description: Cloudy/Blurry AC screen?
Solution: Pending
Problem: Cargo net panel separation
Description: 2010 Cargo Net issues and resolution (panel separation)
Solution: Toyota has suspended sales of the nets while they work on a solution. Some have found temporary fixes as detailed in the link above.
Problem: Delay in answering calls with Nav and Bluetooth
Description: Delay in answering phone w/Nav
Solution: Pending
Problem: Satellite radio signal is weak
Description: 2010 Prius - Satellite Radio Signal Weak
Solution: Pending
Problem: Satellite radio display is truncated to 16 characters
Description: Satellite Radio Character Length
Solution: Pending
Problem: Ghost image on speed display
Description: Double Vision on Speed Display
Solution: Pending, although some have observed that the intensity of the ghosting effect depends on the driver's head position.
Problem: Brakes grabbing in reverse
Description: braking in reverse
Solution: Pending, although some have found ways to avoid it, and others claim the problem goes away after a few weeks.
Here are a bunch of them. Some you mentioned and more
Stupid things about a great car - PriusChat Forums
3-day old 2010 Prius already in shop - advice needed - PriusChat Forums
Fix for difficulty seeing red arrows on Energy Monitor Screen in daylight (2010 Prius II)? - PriusChat Forums
Brake problems???? - PriusChat Forums
Prius Deal Breaker - PriusChat Forums
Dash Rattle... already! - PriusChat Forums
Disappointing G3 exterior - PriusChat Forums
Red Background on Multi-info Display - PriusChat Forums
Navigation Package or not? - PriusChat Forums
Radio reception on base model.... - PriusChat Forums
Do the hoods work with the NAV system? - PriusChat Forums
2010 Cargo Net issues and resolution (panel separation) - PriusChat Forums
Air conditioning noise - PriusChat Forums
Average fuel consumption and average speed since reset not working - PriusChat Forums
Cloudy/Blurry AC screen? - PriusChat Forums
Nav Screen Freezes like a bad DVR - PriusChat Forums Prius 2010 leaking? Please don't say it is so. Picture included :( - PriusChat Forums
2010 rear bumper bottom plastic problem? - PriusChat Forums
Why is the NAV screen of such crappy quality? - PriusChat Forums
Fuel Gauge is too conservative? - PriusChat Forums
AC compressor noise? - PriusChat Forums
Front end too low to the ground? - PriusChat Forums
Anyone doing warranty repairs on G III ? - PriusChat Forums
Double Vision on Speed Display - PriusChat Forums
Loose parking brake pedal pad - PriusChat Forums
Flimsy Rear Spoiler? - PriusChat Forums
IV would not move after stopping - PriusChat Forums
Slip indicator comes on when at a full stop - PriusChat Forums
Has anyone noticing Air Flowing through the driver side door handle? - PriusChat Forums
1 - 3 of 3 Posts
