I just got 3 quarts of Mobil 1's 0W-20 since it's a perfect match for what the book says the car's designed for. However I need recommendations on the best oil filter.
Also, Mobil 1's 0W-20 Pure Synthetic is a 7,500 mile oil, so I plan to change it around there. But supposedly this car can get 3750-7000 miles on regular oil just because of how small the engine is and such. Regular engine oil is usually changed every 3000 miles. It surprised me when the book said 3750 miles only if you drive under severe situations and you could change it at 7000 miles if your nice to your car. That's unheard of on regular oil. So my assumption is you can probably get a lot more than 7,500 miles out of Mobil 1 Synthetic but to be safe I'll change it around there anyway.
I know that the oil can do 7,500 miles maybe even more in the Insight but how about the oil filter. Will the oil filter be able to last 7,500 miles or is it still designed for 3000 miles like regular oil? So even if I don't change the oil I have to remember to change the filter every 3000 miles? I need a good high endurance oil filter then that can last 7,500 like Mobil 1's synthetic.
Also, I see all these things about 5W-20 oil and 0W-30 oil, what's the difference and is it bad for our car? I live in South Florida under usually very hot conditions, it never dips below 70 degrees (farenheit)in the winter and usually never below 77 degrees in the summer. It's usually quite humid outside if not raining. Will 5W-20 or 0W-30 produce different results in gas mileage, engine wear, etc? Or should I stick to factory recommended 0W-20?
