1 - 16 of 16 Posts
Ok tonight on my way home my insight started to do a funny thing.
when I would get to about 4000 RPM the Revs seemed to have no resistance and easy went right up to 6000 RPM, Problem was the car wasnt going any faster...
It did this in all gears (Didnt get fast enough to try 4 or 5) but the forst three.
When I got home all I could smell was a really bad Burning smell, i popped the hood and the smell was worse, it was too dark to see
The IMA is fine, this has nothing to do with battery, anyone know what sort of mechanical problem i could be facing?? Should I have my car towed to honda??
Your sure it wasn't a clutch smell? 4K is the Vtec threshold so you get more power right there and it sounds like something in the equation isn't able to handle the pull after that point. Are you familiar with what burning clutch smells like? It's not the greatest smell in the world.
What you describe sounds like a slipping clutch. Was there any snow on the ground? that could have done it too, it would not explain the smell though.
The gears would still be able to go in just fine with a bad clutch, it would just slip when you apply full power.
There was no snow, roads were dry
Im not sure how to describe the smell, other then gross, i would describe as a plastic smell/rubber smell but my sence of smell is not reliable...
Does something like that mean a new cluctch or could it be fixed?
I've burned out a couple of clutches myself. What you're describing sounds like it, except that you were able to regain some torque. Each time I fried a clutch, stepping on the gas pedal would get me nowhere.
Disclaimer: we're talking about junky cars college students drive; the newest of which was manufactured in 1982.
G
Hi Getshocked.ca:
Getshocked.ca said:
Would something like this be under warrenty??? (I have honda plus 160,000km full coverage)
___Did you recently purchase it or have you had it a few years? If it’s the latter, it will probably be diagnosed as a normal wear and tear item unfortunately.
___Good Luck and let us know what your local Honda dealership finds.
___Wayne R. Gerdes
___[email:3665y1w8][email protected][/email:3665y1w8]
I really really really doubt it'd be warrantied. A clutch is a normal wear and tear item like brake pads. Unless somehow you could prove manufacturer defect I think your going to have to front the cost.
I'm sure you have worn out the clutch.
This is a wear item totally dependent on how the driver uses the clutch.
How many Kms does the car have?
I am sorry to see that you might have to replace the clutch :(
If it is, please do post how much it cost to replace and how much time it takes.
I am an automatic kind of guy and my Insight is manual (no other option in 2000) and I could have been hard on it.
Yeah, I have to go with the others---sounds like a fried clutch----unfortunately. If it turns out to be so, please post what something like that would cost to fix on an Insight.
Murasaki
I have to go with the clutch too. I had an 82 Civic that had shifted fine but slipped terribly under load.
1 - 16 of 16 Posts
