1 - 20 of 29 Posts
See the 3 dots to the right of your post. Click on that and you can edit IIRR.
Sounds reasonable to me.
testing topical info
Hi can I have this restriction removed for me, or can we have it removed for everyone?
I have to edit almost every post I make due to spelling and grammar errors. I almost never make a post and get it right on the first try.
I am not able to lift this for you or for all accounts. You can edit posts less than 24 hours old without it effecting this rule.
-Philip
Post 1
Edit 1
Edit 2
Edit 3
Edit 4
Edit 5
Edit 6
Edit 7
Edit 8
Edit 9
Edit 10
Edit 11
it appears I could do 12 edits in a row, must be hitting the edit timer limit
I just tried to edit my post on this thread from 2 days ago.
Cant do it. I got this message
"You may not edit more than 10 different post(s) within 7 days "
I find it hard to believe that I edited 10 posts in the last 7 days.
Especially if you don't count any edits done in 24 hours of original post.
Yep I get the same, I have edited zero posts outside 24 hours, so it just allows edits that occur immediately after the post and all count toward the quota.
edit...
I can it appears edit this post but i just made it.
That's kind of what I was thinking.
Only edits made within 24 hrs is possible.
This would suck for any posts like I used to do for InsightFest where I am trying to update a roster, or other announcement posts where info needs to get updated as plans change
So if the intent is to allow 10 edits within 7 days, someone in admin needs go back and audit the system to confirm it is properly tacking.
1 - 20 of 29 Posts
