Reader says P0BFD. I can clear it and it comes right back on. Drive Motor A U-V-W Current sensor correlation.
We have replaced the 2010 engine that failed with a 2013 engine, so we have a mix of 2010 and 2013 components in the drive and power train.
Thanks
Mike
Did you re-connect the IMA motor correctly UVW etc?
Check the phase current sensors?
I hope/think we connected the motor correctly. It ran fine for the past two months since the switch. Will have to study up on checking the phase current sensors. I will look for a thread on that next.
Nobody has devulged into the G2 or G3 battery fixing here at ICN.
Good luck.
I got an extra battery when I bought this car. We swapped out the battery packs today and IMA light is off and P0BFD cleared and did not come back. Feeling pretty happy this evening
