Rebound in general is normal...
Looking at this table and the others, I'm asking myself, 'What the hell's going on with taps that you're NOT shorting?' That seems really weird to me. I wouldn't expect voltage to have dropped at all over just a few days. But here you've got -110mV, -110mV, -70mV, -80mV, -100mV on 2,5,6,8,9 respectively...
In my experience you'd have to have a drain on the pack in order to end up with voltage drops like that...
Later... Re-read most of this and the other, short related thread, trying to get a handle on things. One thing I caught: there was driving/IMA usage after the stick-level load tests. After those you put the pack back in the car and said it worked fine. Looks like you got at least a week of usage:
"Reinstalled the battery pack and drove the car for about a week without any codes or issues. About a week ago, a P1449 was set."
So, when I re-jiggered your loaded stick voltage measurements into taps, and compared to your most recent measurements, the difference reflects IMA usage and potential drain/self-discharge. So at time 2, the lower voltages could simply reflect whatever usage the pack saw during that short interval of IMA usage, not self-discharge and/or a potential HV short/drain alone...
What is the current state of your pack? It's in the car, fully installed, but you've got the BCM unplugged and the pack switch OFF. Is that right?
If this is the case, then I think you need to do a few HV measurements again to try to figure out if you've still got some short or what. Basically, I'm back at post #9.
...I wrote a bunch of stuff, some ideas, but I decided they don't make sense - so I deleted it. I'm not sure where to go from here.
